03-20-2006, 10:12 PM | #1 |
6 lug rear disc install done!
Got the new brackets fabricated and welded on today. It was fairly easy to do. I will have to re-powdercoat the rear end but only after all the brake line and e-brake has been mocked up. Brakes are off '03 burb. I would have shown the calipers installed, but they sent me the wrong ones, correct ones should be here in a few days.
Mike
Mike Redpath |
03-20-2006, 10:56 PM | #2 |
River life......
Re: 6 lug rear disc install done!
nice
03-21-2006, 07:30 AM | #3 |
2wd or a 4x4 blazer?
Must be a 4x4 with the 6 lug disks but maybe not. What the overall plans for your blazer? Lift/drive train/gearing/tires...ect. Sorry if I missed that somewhere... Great start with the brakes. |
03-21-2006, 07:46 AM | #4 |
cool - did you use the whole 3rd member from the 03 burb?
03-21-2006, 01:01 PM | #5 |
4wd. I cutoff the old mounting flanges, and made new ones. They went right back in the same location, just clocked differently. Not sure they would fit under stock wheels yet. It has a 13" rotor. I am running 17x9 wheels, so no problem for me there. The best part about this swap is the part cost me $200 including shipping and it is all new GM stuff.
Mike
Mike Redpath |
03-21-2006, 04:24 PM | #6 |
The LuvShack Garage
Sweeeeeeeeeeeeeeeeeet
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-21-2006, 11:24 PM | #7 |
Hey how'bout a parts list and a write up for the FAQ's if it's not too much of a hassle?
03-22-2006, 12:06 AM | #8 | |
03-22-2006, 11:01 AM | #9 |
As soon as I get the e-brake cables figured out, be happy to do it.
Mike
Mike Redpath |
03-22-2006, 08:21 PM | #10 | |
Kevin LFD Inc. |
03-24-2006, 03:39 PM | #11 |
Finally got the rear calipers in. Man, these are huge. It will require a 16" wheel minimum to run these brakes.
Mike
Mike Redpath |
03-24-2006, 06:11 PM | #12 |
Looks great! Keep us posted on a parts list. Did you buy all new parts or used?
Kevin |
03-24-2006, 07:05 PM | #13 |
Got them new off car-part.com. Very good deals on there if you look. Sometimes you can score new stuff like I did for the price of used parts. Never would have got it done this cheap going thru a dealer.
Mike
Mike Redpath |
04-01-2006, 10:18 AM | #14 | |
thanks, Kevin |
04-01-2006, 09:29 PM | #15 |
Designated A-hole!
Can't wait to see the FAQ.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-03-2006, 02:28 PM | #16 |
Got to mount the axle to the chassis before I can figure out which ebrake cables to use. Since I am going with a 4" lift, I may end up using extended cab or long bed cables for the extra length. that will take some guessing. Should be able to finiah that this month. Next time I stop by the dealer I will get a full list of part numbers.
Mike
Mike Redpath |
04-12-2006, 08:21 PM | #17 |
Ttt
07-09-2006, 11:31 AM | #18 |
Musclerodz, any update on the parts list?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
07-10-2006, 07:31 AM | #19 | |
67 is sold
Nice project, I'm interested in the final write up as well
07-10-2006, 07:50 PM | #20 |
Right now I am still trying to work out the brake line that attaches to the rear and e-brake set up. The rear discs are off the shelf 2003 Suburban or equivelant Hollander interchange. The actual brackets are fabricated and can post dimensions. I am working with classic tube to get me the correct setup. As soon as the parts arrive and work, I will post a full article.
Mike
Mike Redpath |
07-10-2006, 09:23 PM | #21 |
Ok I'm kind of a brake Newbee. Should you upgrade the front discs to keep up with the very efficient technology of the new rears?
Also, are these ABS. I can lock up my front discs on my 72' with no sweat.
Rob "RunTMCfan" |
07-10-2006, 11:47 PM | #22 | |
Happy to be here
07-11-2006, 01:50 AM | #23 |
I'm aware of that.
I guess my question could have been read two ways. What I meant was I can lock mine up (stock disc brakes) and that's not good. Does this new conversion have ABS so they won't lock up (good)?
Rob "RunTMCfan" |
07-12-2006, 10:16 AM | #24 |
You will not get ABS because the tone ring, sensors, computer, and ABS controller, speed sensors, etc, would all have to be swapped over. All he did was use the brake hardware itself.
Nice work, I wonder if there is a similar OEM setup that I can put behind my 15" wheels.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
10-16-2006, 04:44 PM | #25 |
bringin it back... any parts list yet?
