Old 04-23-2006, 08:15 PM   #1
ron_n_ca
Question full chassis swap
Hi Guys... Newbie here. I have lurked on this board for a number of months and have recently obtained a 57 swb with a butchered chassis. I have read that using a 67-72 swb chassis is pretty easy by just changing the cab/radiator mounts and that a 71-72 is preferred because of stock disc brakes. I have also read that an S10 lwb can also be used. Has anyone done one of these conversions or does anyone have any constructive comments. Thanks in advance.
ron_n_ca is offline   Reply With Quote
Old 04-23-2006, 10:43 PM   #2
bassfisher
Re: full chassis swap
Hi don't know if this helps, but I have a 57 sb. step side that has ben suframed from a 74 1/2 that seem to work okay. It was done before I got the truck so do not know how hard it was to do? Has ft disc on it been told it was not very hard. Hope this helps.
bassfisher is offline   Reply With Quote
Old 04-24-2006, 12:48 PM   #3
Norselander
Clunker Farm, Proprietor
Norselander's Avatar
I have a complete swb '74 under my '58. The spring hangers out back were moved forward a bit, blocks were installed on top of the front cab mounts, and the radiator support was setup accordingly. here
Drew
Chief Junk Jockey
Norselander is offline   Reply With Quote
Old 04-26-2006, 02:26 PM   #4
55chevy
Car Truck Bike Nut
55chevy's Avatar
HAMB has an article on S10 swap but it's for a pre 55 truck, still may be helpful
http://www.jalopyjournal.com/forum/s...ead.php?t=8491
Snow free Florida panhandle, don't miss Indiana winters
Temp in Suffolk Virginia, Sentenced 2 to 5 years LOL
68 shortfleet project
94 3500 TD dually
so many cars so little time
72 K2 CST 2WD Blazer
55chevy is offline   Reply With Quote
Old 04-27-2006, 07:26 PM   #5
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Welcome to the fourms!
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 04-27-2006, 08:16 PM   #6
ron_n_ca
Thanks to all that responded.... Guess I going to have to pick up a 67-72 factory assembly manual and do a lot of carefull measuring to see how everything lines up.
Old 04-28-2006, 07:22 AM   #7
cadman89
cadman89's Avatar
Here is a 55 on a 72. He used 4" riser blocks under the cab. He also ran the gas fill from the original filler all the way back to the fuel cell in the rear.
http://www.neflnewhomes.com/55chevypu/1955pu.htm
Cadman
56 GMC
1922 Dodge Rat Roadster
89 Gray Allante
90 Red Allante
Turkey Run Photographer http://www.turkeyrun.com/photo_gallery.html
cadman89 is offline   Reply With Quote
Old 04-28-2006, 03:19 PM   #8
ron_n_ca
Cadman,
Thanks for the pics. Good detail of how the fenders were mounted.
Ron
Old 05-02-2006, 12:20 PM   #9
Jebb1978
Jebb1978's Avatar
That truck is sweet cadman! it looks completly stock at first glance!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 05-03-2006, 12:19 AM   #10
qksilver
A trick I did, using a 66 frame was simple. Instead of blocks and all the rigging use the frame brackets off the original frame on to the swapped frame for the cab and core support. Drill, grind/torch the ones off the donor frame, do the same for the original frame. Measure twice, drill new holes in the donor frame and use grade 8 bolts with lock tight. It looks much cleaner and works well.
qksilver is offline   Reply With Quote
Old 05-05-2006, 10:04 AM   #11
ron_n_ca
How did the bed and cab line up when put on the 66 chassis. Did it sit higher on the frame? Was the width any problem?
Old 06-30-2006, 01:15 AM   #12
68c10owner
68c10owner's Avatar
I hate to bring up a old threat but I`m in a similar situation and would be interested in the info about the 66 frame as well.
Anthony
68c10owner is offline   Reply With Quote
