Old 04-29-2006, 09:17 AM   #1
shelby987
shelby987's Avatar
looking for an eaton third
ok, got pulled away from the truck for the last month or so.....but everything seems to be back on track, and I am once again looking for an eaton third with a 4.10 gear set and a locker. If you got one, or know of one, let me know.
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 04-29-2006, 09:20 AM   #2
pumpkin
pumpkin's Avatar
Re: looking for an eaton third
Ive got some 5.56 and 5.13, the 4.10 are hard to find. As far as a locker, one out of a 14 bolt will fit, you just have to use the 14 bolt axles. You can buy the detroit lockers new for about $400.
pumpkin is offline   Reply With Quote
Old 04-29-2006, 10:19 PM   #3
wibilly
wibilly's Avatar
pumpkin, isn't there some machine work also involved in the wheelbearing area of the hubs? i've been thinking about this in order to get a gear ratio in the mid 3's
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-29-2006, 10:24 PM   #4
muddyole 69
I have an eaton with I believe 4.10 not sure if locker or not can check middle of next month when i get in for good from second job if that is not too late let me know Mike and man you gotta remind me as the brain is not as sharp as it used to be later Mike
hav'n fun be'n me
muddyole 69 is offline   Reply With Quote
Old 04-29-2006, 10:44 PM   #5
72 Cheyenne K20
Hey Shelby, I've got a friend from the board that has two 4.11 lockers. He's holding one for me and I think he said he was going to post the other on the board. I'm going to call him this week to set up an install date, I'll ask him if he still wants to sell the other one and get back to you.
Scott
72 Cheyenne K20 is offline   Reply With Quote
Old 04-30-2006, 11:25 PM   #6
wibilly
wibilly's Avatar
if shelby passes on that locker for some reason i would be interested
Old 05-01-2006, 09:45 AM   #7
pumpkin
pumpkin's Avatar
I'm not shure of what you mean by your question. The detroit locker for the eaton and 14 bolt are not complete differentials. They are just the parts to replace the spider gears. The differential housing is bolted togeather. I don't know if the ring and pinion, or differential assy are interchangeable between the two. I like the eaton as it is the strongest diff, by design. I solve the brake problem of getting drums, that are unavailable, by converting to discs. I use cadilac rear calipers that have the parking brake built in.
Old 05-01-2006, 05:44 PM   #8
breeh
Recovering 67-72 Addict
breeh's Avatar
I have a 4.10 NoSpin (locked rear) Eaton. It is still under a parts truck but if you really want it then I will pull it.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 05-01-2006, 07:12 PM   #9
pumpkin
pumpkin's Avatar
I' m interested, next in line. how much?
Old 05-02-2006, 01:23 AM   #10
breeh
breeh's Avatar
pumpkin, I will let you know after I talk to shelby.
Old 05-09-2006, 04:51 PM   #11
breeh
breeh's Avatar
Does anyone know how many teeth this ring gear should have on it to be a 4.10? I can't really see the pinion well enough to count and divide.
Old 05-09-2006, 07:08 PM   #12
71/454
Turbo Guy
71/454's Avatar
The ring gear should have some numbers on the edge, i don't remeber the order they're in but i think you just have to divide the big number by the little one
71/454 is offline   Reply With Quote
Old 05-09-2006, 08:33 PM   #13
shelby987
shelby987's Avatar
breeh, your pm box is full
Old 05-09-2006, 09:16 PM   #14
breeh
breeh's Avatar
Sorry, PM box fixed!
Old 05-10-2006, 03:19 PM   #15
breeh
breeh's Avatar
shelby987, look at this other post of yours and there are pictures to help ID a locker. You can see on mine that there is no inner gear. Also, I have confirmed it as a 4.10.
http://67-72chevytrucks.com/vboard/s...ighlight=eaton
Old 07-31-2008, 06:31 PM   #16
wrangler94
I know this is resurrecting an old post, but do any of you guys have a 5.13 third for a Eaton? I'd be interested, especially if it's got a locker, but beggars can't be choosers.
wrangler94 is offline   Reply With Quote
Old 08-01-2008, 10:29 AM   #17
pumpkin
pumpkin's Avatar
Well I don't know about swapping in the whole diff carrier, but the locker itself comes out of the 14 bolt carrier and goes into the eaton carrier.
Old 06-19-2009, 06:57 PM   #18
rustbucket53
rustbucket53's Avatar
I am looking for a 67 to 72 3/4 ton 3rd member with 4:10 gears to swap out my 1953 3600 3rd member. Anyone got one that will work?
RB53
rustbucket53 is offline   Reply With Quote
Old 06-19-2009, 08:28 PM   #19
wrangler94
RB53
Mine might be 4.10 but i think it's 4.56 I'd have to check.
Old 06-20-2009, 08:34 AM   #20
rustbucket53
Wrangler,
let me know if it is 4:10...if you want to sell it.
I think mine is 4:56...very low gear. I am just trying ot get something so I can keep up with traffic.
How would I tell the gear ratio?
Rich
