Old 05-16-2006, 01:42 PM   #1
swissfacade
swissfacade's Avatar
Installing an 83 tilt into a 69 burb
Has anyone done this, It looks like I will have to replace my brake pedal assembly with a 73-87 one. Also will I still be able to use my 67-72 power booster, master cyl and Prop valve set up.
swissfacade is offline   Reply With Quote
Old 05-16-2006, 05:57 PM   #2
Superron21
DONT TRY THIS AT HOME!
Superron21's Avatar
Re: Installing an 83 tilt into a 69 burb
are you doing this for the tilt wheel feature or for the security of locking steering? because the van tilt columns from the '70's will bolt in.
Superron21 is offline   Reply With Quote
Old 05-16-2006, 06:15 PM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
doesnt the 83's have the ignition in the column?
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 05-17-2006, 12:56 AM   #4
swissfacade
The 83 tilt has the ignition in it, cruise control and locking ability.
What years in the 70's did the vans have a tilt that will fit.
Thanks John
Old 05-17-2006, 06:05 AM   #5
Superron21
Superron21's Avatar
i know the '75, '76 and '77s will work, some had a different shaped plug for the turn signals,and there are adapters available, one is curved and one is flat, check yours and get one like it,
good luck!
Old 05-19-2006, 12:16 AM   #6
wibilly
wibilly's Avatar
81 was the last year van tilts had no ignition lock
common sense isn't so common anymore
wibilly is offline   Reply With Quote
