Old 05-23-2006, 01:29 PM   #1
crossy
Oh,you can't buy that new
crossy's Avatar
1995 No heat or A/C power - nothing works?
I borrowed a friends complete control panel and tried that but still nothing worked.
I have nothing operational in the HVAC control panel. The one heavy orange wire that runs to the panel does have continuous 12Volts but i cant see where as that wire even has anything to do with the power supply anyway, it dead ends into one of the connectors.
none of the switches or controls get any response.
I checked EVERY fuse in the fuse box and in the underhood relay panel.
I ran a hot wire to several of the connections at the dash and i can hear the electric doors opening and i can get each of the fan speeds??
DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 05-23-2006, 08:01 PM   #2
partsman9606
a country boy can survive
partsman9606's Avatar
Re: 1995 No heat or A/C power - nothing works?
sounds like a bad ground possibly
1991 c/1500 lowered 2/4, 6inch cowl hood
1988 c/1500 plain(girlfriends truck)
1999 chevy tahoe z71
partsman9606 is offline   Reply With Quote
Old 05-24-2006, 02:09 AM   #3
crossy
crossy's Avatar
I wiggled and jiggled everything originally and i still got nothing at all. I'm going to splice into the black ground wire and run a separate ground b/c I already had to repair radio wiring that was mangled and they may have originally shared a common ground wire even though the harnesses are separate. I'll let you know tomorrow evening. Seems i dont havea complete circuit and since i verified power to the controls it only seems logical that the circuit is'nt complete. thanx , DAVE
98 Vortec project.
94,3500,6.5L 4L80
Old 05-24-2006, 08:09 PM   #4
partsman9606
these trucks electrical systems are kind of screwy, if foung thes always have a hot lead to them and the switches break the ground so thats why i suggested that! Danny
Old 05-25-2006, 12:48 AM   #5
crossy
crossy's Avatar
The ground wire was not the issue. Problem continues, There is a power wire leading in that has only 3-5 volts MOST of the time. All of a sudden the voltage will spike up to 12Volts and the control will work and the blower fan will come on?? If you change any of the knob settings it will kick back off and you won’t get it to come back on until ?????. If you leave it alone it will continue to run for however long??? WOW I’m confused . the low voltage is over at the fuse box also so I need to find out where the fuse box gets it power feed from. I suspect something bad in the relay bnox under the hood but i already changed that out and no difference.
DAVE
98 Vortec project.
94,3500,6.5L 4L80
