Old 05-30-2006, 03:03 AM   #1
jmbstudios
Pickin' and a Grinin'
jmbstudios's Avatar
Loose Column shift lever.
After rooting around for a while, and probably not looking at the right spot, I
would like to ask if there is a way to tighten up my shifting lever on
my burb. It goes into gear just fine, but there is a lot of play in it.
It is loose and flabby........ I want to replace it (in the future, but would like to find a temporary solution now)
Thanks for the help...
jeff
jmbstudios is offline   Reply With Quote
Old 06-02-2006, 06:59 PM   #2
jmbstudios
jmbstudios's Avatar
Re: Loose Column shift lever.
anyone..........anyone...............Bueller..............
By the way... It is an automatic.
I migiht have mis-named the part...
thanks
jeff
Old 06-02-2006, 10:44 PM   #3
Frizzle Fry
Frizzle Fry's Avatar
OK, let's start with the obvious. Is the pin that holds the actual lever in right? Is it worn? You probably have a little play in several places. Beyond that, check the linkage from the column to the tranny. There are several places in there that can get loose.
Frizzle Fry is offline   Reply With Quote
Old 06-03-2006, 06:03 AM   #4
jmbstudios
jmbstudios's Avatar
Thanks Mr. Fry.
