Old 10-16-2006, 10:27 AM   #1
GlennBrittain
Finally got her down naked
My frame that is
Now that I have my frame completely dismantled, I have some decisions to make. I do still need to remove the cross member from the 7?? frame in the background. First, do I sand blast and use traditional primer or one of the paint over rust products. I have previously posted my bad experience with Eastwood’s product, so it is out. Second is the topcoat to use. Next, I need to decide if the truck will be mildly lowered or stay stock. I live on dirt and some rock road. The truck will be a daily driver and see some light towing. Then rear end ratio, posi unit, gas tank and location, and motor: gas or diesel. I have a 6.2 diesel that needs a rebuild but will have to start from zero on gas. I will be posting progress however slow it will be as “My Farm Truck Progress”. All suggestions and ideas will be appreciated.
GlennBrittain is offline   Reply With Quote
Old 10-16-2006, 06:12 PM   #2
Ram-Man
Ram-Man's Avatar
Re: Finally got her down naked
I had mine sandblasted then I applied self etching primer, filler primer and a catalyzed synthetic enamel. (Martin Senour #6098) They call this chassis black but it is basically a semi gloss high quality paint. I am very happy with the end result. I'm am not a fan of any product you apply over rust.
Ram-Man is offline   Reply With Quote
Old 10-16-2006, 08:22 PM   #3
qksilver
The only benifit of changing crossmembers to the later style is that it is easier to remove the oil pan.
Otherwise everything will swap over
qksilver is offline   Reply With Quote
Old 10-16-2006, 08:27 PM   #4
84 400
Sb 400 club
84 400's Avatar
nice work! for the second coment do you have a link to these products don't mean to hijack but i am thinking of doing a frame of on a 54 willys pick up thanks
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
