Straight jacket required
sway bar bracket????
I know ECC makes these brackets for stock and lowered applications, but when using with airbags, which ones do I use? CPP says stock, any ideas or experiences here???
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." ![]() |
Re: sway bar bracket????
I used the lowered one on my bagged truck.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Happy to be here
![]() Join Date: Mar 2000
You can use the lowered ones, or don't use any at all. You can bolt the bushing clamps directly to the frame. You just want to make sure the bushing on the control arm doesn't bind up....
Thanks guys for the responses. I may go without brackets. I just didn't know if there would be a problem when I aired out or with clearances elswhere.
Junior Member
depending on which sway bar you go with, you will probably need to install the taller bracket in order to drop the mounting position of the bar.... this will keep your ends aligned better......
Thanks Tony.
Questionable
So, just to clarify on this point:
In my '68, I'm running bagged with 2.5" drop spindles. I have a stock swaybar from a 73-87 pickup/van. I have the "raised" swaybar brackets from ECE ($19). This setup will work with no problems? I keep seeing all these pictures of people using some aftermarket swaybar with holes in the ends that bolt to a Q-Tip looking contraption with bushings. I just wanted to make sure I'm not looking for trouble or anything ![]()
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Those are ART's new 'end-link' design to minimize binding w/air suspension travel limits.
Questionable
It looks like CPP has a similar unit, I imagine ECE does as well.
Can you define "binding" for me? I'm tryin to assess whether this is going to be a genuine problem for me.
The end of the bar get's shifted to extreme angles & forces the bushings to be mis-aligned w/the bushing bracket that bolts to the a-arm.
stock sway bar with no brackets on a bags & spindles
#12 | |
Questionable
#13 |
Tot Roddin'
I believe it was Frizzle Fry that posted the FAQ on mounting the sway bar directly to the frame. I'm not bagging my truck, yet...., but I'm planning on mounting the bar directly to the frame when I do lower my truck.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#14 |
Happy to be here
Scoti was the first one that I know of on here to go direct mount. That was before ECE offered the shorter brackets. Besides, Scoti was too ...uh ...frugal... to buy custom brackets....
#15 |
Tot Roddin'
I know where he's coming from...
![]() Thanks for the correction N2TRUX.
#16 |
1972 Chevrolet SWB
I used original brackets and just placed my sway bar inside of the brackets instead of under. Worked like a charm.
You can see it in this picture. ![]()
My New thread with pics (not my build thread yet.) ![]() http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. Last edited by slammed1; 03-11-2008 at 06:22 AM. |
#17 |
Questionable
cool setup, slammed1
effectively, the ECE bracket puts them in the same place, and a pair of brackets is less than $20, so I had them work it into my 5-lug axle order! ![]()
#18 |
gearhead
i cut the back off my brackets and turned them around so it wold move the bushing up to the frame and still keep it out of a bind.
2003 GMC Z71 Daily driver ![]() 1982 Chevy 2wd short bed, project, ![]() boxerdra@hotmail.com ![]() |
#19 |
Questionable
very cool, and nice friggin frame! i hope mine looks that sweet when it comes back from powder
#20 |
Tot Roddin'
#21 |
![]() Join Date: Aug 2005
That's a great set-up. You can only go so low with them mounted directly to the frame. I had to make brackets for mine after I bagged it.
#22 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#23 | |
Questionable
#24 |
A guy with a truck
Well, I guess I don't feel like too big of a douche...
#25 |
GM ONLY BABY!!!
I have a 72 GMC, bagged, 3" drop spindle, stock sway bar, lowered sway bar mounts, and it seems to work ok for me. No problems yet.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
