Old 11-18-2006, 01:24 PM   #1
mntoy
1974 C20 still have brake problem
Never got my brakes fixed, I bench bleed my MC again, and leveled the truck and did it on the truck too. Back brakes bleed out great and stiff but the front brakes stll have lots of air, not sure why. I have bleed them manually by pushing the brake pedal and used a speedy bleed but lots of air keeps coming out even spurts large bubbles. When I go to fill the reservori small bubbles rise out of the front brake reservoir only(the one for the front brakes is what I mean). while the truck is off the pedal is great but when I start the truck pedal goes straight to the floor and does not come back up. What am I doing wrong, I have been through two quarts of brake fluid bleeding and it has not gotten any better. the brake light does not come on and I have tightened every fitting for the front brakes. Any help out there?
mntoy is offline   Reply With Quote
Old 11-18-2006, 03:04 PM   #2
mntoy
Re: 1974 C20 still have brake problem
found a leak problem solved
Old 11-18-2006, 04:44 PM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Cool... Good to hear.
Where was the leak at?
Almost time to get it out on the street and drive it like you ...
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 11-19-2006, 10:33 PM   #4
mntoy
It was at the passanger side where the steel line meets the rubber hose. Not sure how that happened.
Old 11-21-2006, 12:06 PM   #5
boxrodz
boxrodz's Avatar
Sometimes the smallest things causes the biggest headaches... eh.
It probably stops 'almost' as good as it goes.
boxRODz
Old 11-21-2006, 08:52 PM   #6
marvxyz1
marvxyz1's Avatar
You may have a air leak at the place where the rubber line connects to the frame. There are copper washers at the fitting to seal the connection
You might try using new copper washers there Or even double washer it there. I know I had a dickens of a time trying to seal my fittings there.
marvxyz1 is offline   Reply With Quote
