11-23-2006, 07:42 PM | #1 |
A guy with a truck
Looking for a measurement
Searched and came up empty. Looking for the distance between spring perches on a coil rear at the axle CL. Trying to get all my bases covered before I tear into this Blazer project...
Thanks -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
11-24-2006, 03:00 AM | #2 |
Re: Looking for a measurement
Are you talking about where the trailing arms bolt to the axle? I have an empty axle housing in my back yard that I could measure for you, if that's what you're looking for.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
11-24-2006, 09:55 PM | #3 |
A guy with a truck
Exactly what I am searching for. Guess I wasn't very clear in calling them 'spring perches', as technically that's not what they are. Somehow that's what my brain spit out as I typed...
11-25-2006, 03:47 PM | #4 |
Ok, Here's what I got.
I couldn't take an accurate measurement right on the centerline of the axle because of the differential housing. From center of rear hole on the driver's side to center of rear hole on the passenger's side measures 41 1/4" (See Pic 1) Since I'm not sure if this is 67-70 1/2 or a 70 1/2-72 axle I measured from the outside of the differential cast housing portion to the OUTSIDE of the brake flange (for lack of a better word) and it measured 21 1/8" on both sides. (See Pic 2 - Red Line) From the center of the rear hole to the OUTSIDE of the brake flange measured 8.5" on the driver's side & 8 11/16" on the passenger's side. (Pic 2 - Yellow Line) From the center of the front hole to the OUTSIDE of the brake flange measured 9 11/16" on the driver's side & 9 13/16" on the passenger's side. (Pic 2 - Green Line) I can't honestly say that my measurements are 100% accurate, but they are +/- 1/8". From what I have seen there is plenty enough play (side to side) in the trailing arms, even with new Poly bushings, to let you be off a little and it not make a difference. Let me know if you have any questions on my measurements.
11-25-2006, 03:53 PM | #5 |
A guy with a truck
Awesome man. That is perfect. Many thanks. -Chris
11-26-2006, 12:47 AM | #6 |
Another handy thread going on my subscription list. THX!
1986 C10 - LWB, 305/700r4, posi, vortec heads |
11-26-2006, 12:48 AM | #7 |
No problem guys, I know ya'll would do the same for me.
11-26-2006, 09:02 AM | #8 |
The LuvShack Garage
Right Click and Save, TYVM
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
11-26-2006, 02:43 PM | #9 |
A guy with a truck
Krue- FAQ?
01-18-2011, 02:55 AM | #10 | |
But Found Her 25yrs Later!
Another great post, in an old thread.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
03-03-2014, 11:06 PM | #11 |
ahhh,finally found the answer i been looking!,Thanks..!!
