Old 11-24-2006, 06:35 PM   #1
timcos
Chief Honcho In Charge
timcos's Avatar
One way to install universal windshield washer pump
This comes from some electrical help from Putter. Thanks Putter
This installation will allow the wiper switch (when depressed) to squirt the fluid.
1. New circuit for water flow
a. Install pump to fender ahead of the reservoir or your own chosen location.
b. Attach tubing from reservoir to suction on pump.
c. Cut old tubing at firewall.
d. Extend back the squirter tubing in your hand and cut to equal length (long enough to meet in the middle.) Be careful to not tug too hard and pull them off the squirters.
e. Attach squirter tubing to new T (comes with universal pump) and attached new hose (6 ft – 4.99 at checkers) to third leg of the new T.
f. Run new tubing down the guide to the side of the truck and forward. Attach it to the output of the pump
2. New electrical circuit so your pump will pump when you depress the stock switch.
a. Attach two wires to pump wire with approved electrical connection procedures.
i. I used 7 feet each of 18 gage yellow (power) and dark blue (ground)
b. Run them into the cab
c. Remove gage panel.
i. http://www.67-72chevytrucks.com/vboa...d.php?t=164357
d. Tap onto the YELLOW wire at the wiper motor. It is switched.
i. Use Yellow wire running to the cab from under the hood for connection.
e. Tap into the dark blue (ground) wire at the wiper switch.
i. Use Dark Blue wire running to the cab from under the hood for connection.
3. Test prior to reassembly.
4. Reassemble everything you disassembled.
The three pics below are
1. The tee under the hood near the cowl.
2. The pump motor location and routing of wires and hoses (5/32)
3. The electrical taps at the wiper motor and the switch.
1992 1500 4x4 Shortbed
1984 Ford F250 Supercab Longbed 6.9L Diesel
1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
1967 C10 SWB (1980-1981)
1971 C10 LWB (1998-2004)
timcos is offline   Reply With Quote
Old 11-24-2006, 10:58 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: One way to install universal windshield washer pump
or you could get a washer bottle/pump assembly for a motorhome and bolt it to the back of the rad support. mine holds a full gallon and sprays quite nicely. my next change is to install squirters from a early 90s F150 on the cowl.
68C15 is offline   Reply With Quote
Old 11-24-2006, 11:05 PM   #3
timcos
timcos's Avatar
Yes exactly...that is my next move.
This will hold me through the winter. I need to get rid of that voltage regulator first...CS130 alternator coming this winter to a truck near me.
1971 VW SuperBeetle
1960 Wife
1984 Son
1986 Son
1989 Son
Previous Trucks
Old 07-03-2016, 10:51 PM   #4
In The Ten Ring
Nice work....I am ready to do this same thing with the same exact replacement pump.
Is there something wrong with installing the pump with the intake outlet pointed upwards?
In The Ten Ring is offline   Reply With Quote
Old 07-05-2016, 07:01 AM   #5
randy.powell
Where/what kind of pump did you end up using?
TIA,
Randy
randy.powell is offline   Reply With Quote
