11-28-2006, 10:04 PM | #1 |
K&N Air filter vs Paper: Test results
I wanted to see for myself what the difference was between K&N Air filter vs Paper (NAPA). So here's what I did. I ran each filter about 5500 miles then sampled the oil (Mobil 1 10w30) and sent it to a lab for analysis. Here's the particle count results:
K&N SIZE NUMBER/ML 4 um 37960 6 um 1449 14 um 139 21 um 33 38 um 20 70 um 13 ISO 11171 CODE: 22/18/14 Paper: SIZE NUMBER/ML 4 um 419920 6 um 4860 14 um 113 21 um 75 38 um 45 70 um 30 ISO 11171 CODE: 23/19/14 If I'm reading this right, the paper filter (which actually had a few hundred less miles on it) was dirtier! Same truck, same driving conditions. Only difference: I was using a Delco oil filter on the K&N and a NAPA Gold oil filter with the paper. I was really suprised! I expected the opposite results. So it looks like the K&N is superior- at least on my truck. What say you?
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! |
11-28-2006, 10:14 PM | #2 |
Re: K&N Air filter vs Paper: Test results
Wow....
Hmmmm. I'm running a K&N air filter. This is good to see. Thanks for your efforts
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
11-28-2006, 10:21 PM | #3 |
That is the first one I seens that slants towards the K&N............Have friends with diesels and it was the exact opposite.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
11-28-2006, 10:31 PM | #4 |
its all about the +6 inches
yep, every test i've seen..which were all done in controlled environments, show the K&N as being next to worthless.
11-28-2006, 11:01 PM | #5 |
Since you sent the oil in I am assuming that the particle counts are from the oil correct?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
11-28-2006, 11:16 PM | #6 |
NOT REALLY BANNED!
It appears to me that the paper filter is superior to the k&n on your truck, as the el-cheapo filter was dirtier, thus it caught more sediment and particles within your oil system.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
11-28-2006, 11:34 PM | #7 |
My daily driver goes faster and better mpg with a K & N only because my wallet is lighter.
11-28-2006, 11:47 PM | #8 | |
My buddy works for a company near Forest City Iowa, they make oil filters. I just learned the other day, that they supply filters to all the major companies (Fram, Napa, purolator, etc), the filters come down the line, and then the outer casing get's painted to the specifications of the brand. Aparently they all use the same filter, the only difference is the paint job.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
11-29-2006, 02:09 AM | #9 |
Interesting. Ive never really heard anything bad about K&N's before. Spent all that money for them in both trucks & had myself believing that those ugly expensive filters looked ok. Now I find out I can put a paper element back in & feel better about the filtering quality & the looks...
11-29-2006, 02:40 AM | #10 |
I noticed a big difference in perfomance with a K&N on my 91 Silverado 350 EFI. No more bogging out on long hills in 5th gear.
11-29-2006, 03:24 AM | #11 |
Saving 1 truck at a time!
I think someone missed the point. Very interesting results! I ran K&N's on my desert racer for years. The paper air filters resulted in less time between re-ring jobs and more dirt in the inlet passages.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
11-29-2006, 05:57 AM | #12 | |
11-29-2006, 09:11 AM | #13 |
Java Mechanic
It was the oil, not the filter element, that was sampled.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-29-2006, 11:37 AM | #14 |
untill i joined this forum i always went k&n. now all i hear is how bad k&n is. where did the K&N does not stop dirt come from? i hade a 5.0 mustang that ran up and down about 10 miles of sandy, red clay road daily for 3 years. i tore the motor down at 114000 miles, it was a waste of time, nothing wrong and showed almost no wear. that car had k&n on it from day 1. pkj
11-29-2006, 12:10 PM | #15 |
Active Member
I also ran a K & N on my truck and when I tore it down to rebulid the engine clean as can be. The same goes for all of my quads I run K&N and not one problem with sucking in dirt even at the sand dunes, mountains, etc.
11-29-2006, 12:23 PM | #16 |
The only problem I had with a K&N filter was on my Dodge Cummins diesel. The turbo would suck the oil out of the filter and gunk up the blades on the turbine wheel. After I found this happening, I went back with a big paper filter. Just my .02.
AndyT
'72 Custom Deluxe C-10 Allis Chamlers 4 cyl. Turbo Diesel engine, Ford granny low 4 spd. trans. '91 Dodge D250 Cummins Diesel Antique Pulling Tractors: 1956 Allis WD45 Diesel 1960 Allis D17 Diesel 196? Allis D21 Diesel |
11-29-2006, 12:26 PM | #17 |
Active Member
If the filter is oiled to much that will happen I have had a couple of buddies have that problem until I saw them spray the oil on the filter it only takes a very thin coat.
11-29-2006, 12:38 PM | #18 |
Keepin an eye out
I have had good results with K&N filters over the years. Proper maintenance will yeild proper results.
They hate them on the 4x4 boards.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
11-29-2006, 12:38 PM | #19 | |
I personally will not run a K&N air filter. Their oil filters are okay but not worth the extra money in my opinion by any means. I use Napa Gold (Wix aka afinia) on everything I own. Starting to make the switch to Royal Purple too (already switched my DD to Royal Purple and WHAT A DIFFERENCE...) just my $.02
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
11-29-2006, 12:43 PM | #20 |
amsoil nanofibre air filter is supposed to be the chit! amsoil teamed up with donaldson (heavy duty diesel industry) to produce light vehicle air filters.
https://www.amsoil.com/StoreFront/eaf.aspx http://www.donaldson.com/ Problem with K&N is it's made of cotton... Cotton shrinks when wet... so you have to make sure it is properly dried and oiled before reuse when just cleaned
May all your ups and downs be in the back of a Chevy!: |
11-29-2006, 01:40 PM | #21 | |
I am fascinated by this. All I can say is that I'll contiune to take oil samples- this time with the same oil filter. To be sure this is not a controlled environment but it is real life, everyday, on the truck I drive. A few more tests should produce a reliable picture. I'll be sure to post results so you guys can scratch your heads along with me. One side bar. My tests showed a moderately high lead count (around 90 ppm on each test) I have around 25000 on that engine. Bearing wear I presume. I occasionaly haul a 1000 pound trailer in 100+ degree heat. Other than that, every day driving. Any ideas on slowing the wear? Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 11-29-2006 at 01:42 PM. |
11-29-2006, 02:02 PM | #22 |
I've not noticed any difference in mine either in git up & go or mileage. I suppose if I dyno'd the thing I see something.
11-29-2006, 02:04 PM | #23 |
Out of the carpool lane.
I'm just curious where you take your oil in to get sampled?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
11-29-2006, 03:18 PM | #24 |
Oil Analysis Labs Inc. There are a bunch of these type labs around.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 11-29-2006 at 03:28 PM. |
11-29-2006, 06:07 PM | #25 | |
