Old 08-19-2002, 02:53 PM   #1
6869704X4
Brakes
Would like to hear what brake setup yall are using. Especially with big tires. Ive got a conglomeration of pieces from 70-74. My truck stops OK but sometimes I wish I had a little more power. Anybody have a setup where they've ditched the factory proportion valve and ran an aftermarket one like a Wilwood?
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-19-2002, 11:41 PM   #2
DaHateTank
I have 36" tires. Don't know if you consider that big, or not. IMO, its sorta 'middle sized'
Anyway, I currently am running the stock '72 half ton disc/drum setup. Ive never really had any problems with it, except for a master cylinder failure, that resulted in a little trip over the curb, and through the ditch!
I can't blame that on any shortcoming, in the brakes performancewise, as it was more of a failure. To be expected on a 100K mile truck, I 'spose.
I am planning a conversion to 3/4 ton running gear, with a home brewed 4 wheel disc setup, likley using front calipers, as per the common procedure.
Id be interested to hear more details, on what pieces you are currently running...
-Marty
DaHateTank is offline   Reply With Quote
Old 08-21-2002, 05:31 PM   #3
kpf
brakes
I have a 71 3/4 ton and I'm running the stock front disc and have the 12"x2-1/2" drum in back. Tires are 35's. Just went through and replaced everything including proportioning valve
now brakes work excellent. (just a tip - completely bleed the system of all old fluid)
kpf is offline   Reply With Quote
Old 08-21-2002, 05:52 PM   #4
6869704X4
Im running 36s too. My rears seem to lock up a little early. Maybe when I put my bed back on they will be allright.
kpf, where did you get the pro valve?
Old 08-22-2002, 09:43 AM   #5
kpf
6869704x4
The only place I could find the valve was through the local chevy dealer. I think it was about $90 or so. I was having the same problem with the rear brakes locking up. Even after I replaced everything they were still locking. After a thorough bleeding of the system everything works great.
Old 08-22-2002, 03:31 PM   #6
6869704X4
Thanks man.
Old 08-22-2002, 10:04 PM   #7
DaHateTank
Im thinking' you can buy an aftermarket prop valve for about $40...
You just put it in the line, and use it to regulate the amount of flow to the rear brakes, if Im thinking right...
unlike factory one, it would be adjustable, which will help compensate for non stock pieces, in the system...
Also I would agree that hving the box off, would tend to aggravate rear brake lockup.
-Marty
Old 09-12-2002, 08:31 AM   #8
MOTHERTRUCKERS
We stock the WILDWOOD adjustable valve and run them on everything. They are great for tuning your brakes in on non stock or modified trucks. We also have G.M. valves in stock. e-mail if interested.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
