Old 12-15-2006, 04:22 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
Question annoying squeaks solution?
i just greased all the zirc fittings i could reach on my 2 wheeler front end. my truck still squeaks as much as before. im wondering if it could be my body mounts? has anyone else had the squeaks? they are almost constant when im driving slow.
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 12-15-2006, 10:32 AM   #2
Burt4x4
Burt4x4's Avatar
Re: annoying squeaks solution?
When I put on Poly body mounts my 'road squeeks' were much much less...so yes new body mounts will help.
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 12-16-2006, 02:28 AM   #3
13lazer
13lazers' blazers
13lazer's Avatar
you had fewer squeaks with polyurethane than oem rubber? i thought it was the other way around? i have both sets, 1 from energy and 1 from l.m.c. are rubber mounts louder?
1970 2wd blazer
Old 12-17-2006, 02:27 AM   #4
jhow66
jhow66's Avatar
Could be your brake pad wear indicator--next time it is doing it while driving slow,lay foot on brake and see if it goes away.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
