Old 01-29-2007, 12:10 AM   #1
2WD_Blazin_79
2WD_Blazin_79's Avatar
Rollpan Tailgate hinges??
I have a 79 Blazer and am looking into a rollpan for it. My question is how can I hide the hinges?
2WD_Blazin_79 is offline   Reply With Quote
Old 01-29-2007, 02:46 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Rollpan Tailgate hinges??
The only way that I know is to to custom make them. It would not be that bad to do. You would have to cut into your roll pan some to do it..
Hope that help..
Trav
tvblazer78 is offline   Reply With Quote
Old 01-29-2007, 03:50 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah I agree, the only way its going to work is if you custom make the hinges. Probably have to cut the roll pan up a little too.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-29-2007, 04:09 PM   #4
Chevyrod
Chevyrod's Avatar
I agree also. I have seen some with the hinges out side the pan. It looks awful. I kind of like the looks of a bumper.
Chevyrod is offline   Reply With Quote
Old 01-29-2007, 08:57 PM   #5
Zoomad75
K5Camper
Zoomad75's Avatar
Are you running a top? Remember a Pickup gate bolts in on the K5 tub. By using the pickup gate you elminate the K5 gate hinges and all. (all the holes are there to bolt up the pickup hardware)
If you still are running a top, you might be able to adapt the pickup style hinge to the K5 gate. Remember the K5 gate uses the torsion springs to aid in lifting/lowering. Eliminating them might require more work.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 01-29-2007, 09:59 PM   #6
2WD_Blazin_79
I thaught of that cause the holes are already there.. I was also looking at my s-10 blazer and I think I can make something similar to the hinges it has as well.
