02-05-2007, 01:19 PM | #1 |
13lazers' blazers
front spring lift ?
i am adding about a 6" spring lift to my 1 ton blazer project. i need to do it as low budget as i can. im making custom spring hangers for the rear, and the front if necessary. i have the 14 bolt rear and the corporate 10 bolt with the big tubes for the front. my blazer is a 1972 loaded cst. i have the rear lift handled. my question is, what vehicles in the junkyard might have thin spongy springs with enough arch to give me the lift i want in the front? any suggestions will be appreciated.
13lazer
1970 2wd blazer 1972 1ton blazer 4x4 in progress 1966 mustang coupe (modified) 1985 c20 suburban tow rig 1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat almost all exempt from california smog laws intentionally. |
02-05-2007, 01:27 PM | #2 |
Re: front spring lift ?
A 1 ton blazer?? I need to see pics of that. Is is a blazer tub on a 1T frame?
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-05-2007, 04:28 PM | #3 |
The LuvShack Garage
Lots of 1ton rigs here, basically a 1/2 ton Blazer frame with 8lug Heavy duty
axles under it, we call em 1tons, but that may not be what you would call it. I understand your budget, but personally I would not use JY springs at all
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-07-2007, 05:15 PM | #4 |
If your going to build new mounts, I've heard of using rear springs up front.
02-08-2007, 06:53 AM | #5 |
13lazers' blazers
my friend has a 1961 scout, he welded new spring mounts farther to the rear of his frame. he used toyota or nissan springs, im not sure exactly. he got a much better ride and more wheel travel. with new spring mounts up front i suppose i have several spring options. as long as i am close i can adjust.
"A 1 ton blazer?? I need to see pics of that. Is is a blazer tub on a 1T frame?" yeah i have a 8 lug 14bolt rear, and a 10 bolt front from a late 70's 3/4 ton 4x4. i dont want blocks in the front, i have access to any size structural steel shapes i need so i guess ill work it out somehow. the lift issue has held me up for more than a year now. ill start posting pics when i start cutting the old hangers off.
02-08-2007, 08:31 AM | #6 |
Let`s get technical here and add a third choice.Why isn`t your Blazer a 3/4t?I can`t wait to see how you do these springs.It`s always cool to find new ways to make it better.
