02-05-2007, 11:57 PM | #1 |
Got Light Emitting Diode?
what do you get when....
you are bored and just bought 100 white LEDs off of ebay???
LED REVERSE LIGHTS!!!
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
02-06-2007, 12:08 AM | #2 |
Re: what do you get when....
cool
02-06-2007, 12:12 AM | #3 |
Freeeeee Mason...
I'd definitely do that mod if I had stock tail lights
02-06-2007, 12:35 AM | #4 |
In Memoriam...
Cool...how 'bout some night-time pics...
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
02-06-2007, 01:25 AM | #6 |
sorry, it wont be soon, my truck lives at my parents house since apartments suck.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler Last edited by 68w/sbc406; 02-06-2007 at 01:26 AM. |
02-06-2007, 01:27 AM | #7 |
BlahBlahBlah
Sheesh I think I just got a tan looking at a PICTURE of your reverse lights.
02-06-2007, 01:29 AM | #8 |
i cant wait till i get a tail gater at night and he is still behind me at a stop light
02-06-2007, 01:29 AM | #9 |
Commander Taco Bello
wow! headlights in replace of your reverse lights.
that should make backing up at night easier |
02-06-2007, 01:30 AM | #10 | |
02-06-2007, 01:31 AM | #11 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-06-2007, 01:35 AM | #12 |
some more pictures of before they were installed
02-06-2007, 01:38 AM | #13 |
well with my hella H4 conversions, PIAA 60/55w super white bulbs, and head light relay i bet if they get in front of me they will not like it
o did i mention i never got around to adjusting them correctly
02-06-2007, 01:41 AM | #14 |
sooo thats what reverse lights look like on these trucks, mine havnt worked since i got it i just hold on the brake pedal enough and use the brake lights..haha..but i would love to have a set of those in my truck, how did you make them???
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
02-06-2007, 01:44 AM | #15 |
i would love to find LED taillights with bulbs as dense as that.
only have 2 vertical rows lit for tail lights, then light them all for the brakes. |
02-06-2007, 01:45 AM | #16 |
I see a FAQ write up in his future.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer |
02-06-2007, 01:48 AM | #17 |
02-06-2007, 01:50 AM | #18 |
Chief Honcho In Charge
That is hot...ouch.
FAQ please
1992 1500 4x4 Shortbed 1984 Ford F250 Supercab Longbed 6.9L Diesel 1972 K10 Cheyenne Super Fleetside Short Bed - 350 - A/C 1971 VW SuperBeetle 1960 Wife 1984 Son 1986 Son 1989 Son Previous Trucks 1967 C10 SWB (1980-1981) 1971 C10 LWB (1998-2004) |
02-06-2007, 01:51 AM | #19 |
Here is an LED setup in the original bulb case that you can plug into the orginal socket. Just like a standard bulb plug and play.
02-06-2007, 01:57 AM | #20 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=223102
02-06-2007, 02:00 AM | #21 | |
http://www.spiderlite.com/
02-06-2007, 09:46 AM | #22 |
Ok I understand the laninate the same shape as the existing fixture with holes drilled in and hot glue gun to hold them in place. But what I dont understandt is how you wire each bulb from only two wire leads from the original bulb metal housing.
02-06-2007, 09:47 AM | #23 | |
Global warming is a myth
I do like the looks of that very much. Looks great! Did you solder the wires together behing the board? Looks pretty simple. Very Later, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
02-06-2007, 09:58 AM | #24 |
LEDs only have two leads, an anaode and a cathode (+ -) the glass part of the bulb was broken out and then i drilled through the bottom of the metal so i could solder the + wire onto the center 'nub' then the - got soldered to the case. then 4 leds got soldered in series +-+-+-+- to devide the voltage by 4 and you now have a complete circuit.
02-06-2007, 09:59 AM | #25 | |
soldered wires, yes
