![]() Join Date: Apr 2000
power heated seats..
got an 03 avalanche and the heated seats just started shutting off after 5-6 seconds?? anyone have these prolbems with there seats??
jamie72 72 BB cheyenne -- Restoration getting started.. member #807 http://www.myspace.com/whitetailobsession www.antlertalk.com |
![]() Join Date: Jun 2006
Re: power heated seats..
I am a service tech at a GM dealer, and I see this a lot.
Have your local dealer check the software in the driver's seat module to see if it is up to date. You can tell them to reference bulletin # 05-08-50-008 Most likely a simple reprogram will take care of this, but it could still have a fault in the heaters, wiring, or module. Generally if a part is bad, they will not turn on at all, even for a second. Hope this helps.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
hey thanks!!! i`ll let you know what i find out!!
any idea what a dealer charges to check this??
