09-02-2002, 02:20 PM | #1 |
Driveshafts and Lift
I have a 72 Jimmy been doing a frame off job on for some time now...anyway I`m to the point where I need to decide on a 2" or 4" suspension lift, I have 2" of body lift in it already. Could someone tell me if I `ll need to get my driveshafts lengthened with a 4" lift, and how bad will it be on u-joints since the Blazer rear shafts are so short and at a steep angle to begin with. Thank You
`72 Jimmy 6" n 35`s `68 Chevy II SS 396 `98 Dodge Ram `01 Audi TT |
09-02-2002, 06:47 PM | #2 |
user # 2756
4" should be no problem. I had an 85 w/ 4" lift and it's driveshaft is shorter then what you have because of the NP208 transfer case's tailshaft.
Welcome to the board!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
09-03-2002, 09:26 AM | #3 |
Suburbans RULE!
When I put a 4" lift in my Suburban I had to have the rear shaft lengthened. When I went to install the rear shaft after the lift I pulled the splines all the way out and I was about 1/2" from seating in the yoke. Obviously too short. The front shaft was fine.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
09-03-2002, 09:51 AM | #4 |
I have 4" on my Jimmy and had no troubles with the stock rear shaft. I first had 1 1/2" add-a-leaves and 2 1/2" blocks but bent the axle housing perches! It now has a set of 4" National springs in the rear but I disposed of the EXTREMELY clapped out stock rear shaft for a Tom Woods CV joint rear shaft. The rear springs tilt the rear axle up to a virtually zero pinion angle which is correct for a CV shaft, but not for a non CV shaft. I had tossed my original shaft out a couple of times after breaking rear yokes and/or u-joints and it was tweaked as well as just worn from 300k+ miles. The new shaft elimintated about 2/3 of the slack in the driveline.
09-03-2002, 05:24 PM | #5 |
Thanks for all your input guys! Sounds like I`ll get by with my stock shaft lenghts and 4" of lift... in a old Jimmy anyway. Now I just have to decide, 33`s with 4" total lift or 35`s with 6" total. Decisions decisions!
09-03-2002, 10:33 PM | #6 |
35's of course. My truck looked supid with 33's I thought. 4.10s and the 33s was too much, but perfect for the 35s.
09-04-2002, 05:14 PM | #7 |
Post Whore
When I did my initial 4" lift on my '69 I did have to have the front driveshaft lengthened and even had to add a CV joint. But mine has the Rockwell T221 transfer case. From what I have gathered, usually a 4" lift on the years after they stopped using the Rockewell (after 69), don't need to have the shaft lengthened.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-04-2002, 08:08 PM | #8 |
The NP205 trucks should come with a CV shaft in the front. At least the 3 I have had did.
09-07-2002, 12:40 AM | #9 | |
--------------- Don't worry about U-Joint life too much, either. When I first lifted my heap, I was going thru U joints quite often. Then I discovered that my yoke was thrashed. After fixing that, the joints last for a couple years, or so. Although thats a pretty short lifespan, when compared to a stock truck, they're cheap, and easy to replace...so, IMO, its no big deal. Well worth it, for the increrased clearance, traction, etc. My beater has a 6" Lift in it, BTW. -M |
09-28-2002, 02:41 AM | #10 | |
that would explain why some trucks have perfectyl horizontal pinion and why some are tilted up/back a bit,.... hmmmmm......... |
