Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ > FAQ Truck Tech > Suspension, Steering and Brakes > Wheels and Tires
Closed Thread
Old 04-04-2007, 08:26 PM   #1
KFreddy
Active Member
KFreddy's Avatar
5x5 Bolt Pattern Compatibility List
Hi all,
Here is a 5 on 5 bolt compatibility list that I have compiled for wheels or brakes. I still have to work out Jeep and Infinity/Nissan. Admin donno if this is FAQ material, but your welcome to do with it as you wish...
Note: 5x5 bolt pattern is also 5x127mm
BUICK LE SABRE, RIVIERA 64-87
BUICK Riviera 64-78
BUICK Roadmaster 91-98
BUICK ROADMASTER, ESTATE WAGON 90-96
CADILLAC Calais 68-85
CADILLAC Deville 68-84
CADILLAC Fleetwood 68-84, 86-98
CADILLAC Seville 77-79
CHEVROLET 1/2 TON BLAZER, JIMMY, SUB FULL SIZE 2X4 71-91
CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 67-87
CHEVROLET 1/2 TON TRUCK ALL MODELS 2X4 88-98
CHEVROLET 1500 ½ Ton P/U (2WD) 88-98
CHEVROLET ALL 5-LUG HALF TON TRUCKS up to 99
CHEVROLET ASTRO/SAFARI 85-on
CHEVROLET Caprice 88-98
CHEVROLET CAPRICE CLASSIC 90-97
CHEVROLET IMPALA SS 94-99
CHEVROLET Suburban 1500 (2WD) 88-98
CHEVROLET TAHOE, YUKON 2X4 92-99
CHEVROLET VAN G-SERIES 1/2 TON 71-96
CHEVROLET WAGONS & HD models 55-95
CHRYSLER Imperial 67-70
FORD FULL SIZE (CUSTOM, GALAXIE, T-BIRD) 73-78
FORD Custom 73-78
FORD Galaxie 73-78
FORD LTD 73-78
FORD Thunderbird 72-76
GMC 1500 ½ Ton P/U (2WD) 88-98
GMC Safari Van 1500 85-2002
GMC Suburban 1500 (2WD) 92-98
GMC Van 1500 88-99
GMC Yukon (2WD) 95-98
JEEP Grand Cherokee ALL MODELS 99-06
LINCOLN CONTINENTAL, MARK III 73-79
LINCOLN Versailles 73-77
MERCURY COUGAR 73-78
MERCURY Grand Marquis 73-78
MERCURY Marauder 73-78
MERCURY Meteor 73-78
MERCURY Montclair 73-78
MERCURY Park Lane 73-78
OLDSMOBILE ALL FULL SIZE 88, 98, RWD (W/403 ENG.) 64-92
KFreddy is offline
Old 11-28-2007, 01:46 PM   #2
Primered_69
Primered_69's Avatar
Re: 5x5 Bolt Pattern Compatibility List
The problems of this list is are we sure the backspacing is correct for these to fit on our trucks. Further are the center diameter of the hold over the hub correct for our trucks.
I just would not want someone spending 300 dollars on take off Jeep wheels to only find they will not fit.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline
Old 11-28-2007, 04:06 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
One thing to be aware of is whether or not the older wheel will clear the disc brake caliper. On a drum brake, it may not be an issue, but with disc brakes, those older wheels may not work.
Member Nr. 2770
'69 C-10 SWB; 350/TH400 - under reconstruction.
ChevLoRay is offline
Closed Thread
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright 1997-2009 67-72chevytrucks.com
