Old 04-08-2007, 01:48 AM   #1
Daniel U
Daniel U's Avatar
paint code ?
I have a '54 Chevrolet 5 window pick up that I'd like to paint a dark GM green. I found the color I want on a 2002 Chevrolet Suburban. I believe the color is called Dark Forest Green. Anyone here happen to have one like this or know what the paint code is? :
Thanks, Daniel U
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 04-08-2007, 02:51 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: paint code ?
or check Polo Green metallic from the GMC's...should be the same thing.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-08-2007, 09:17 PM   #3
bigben
bigben's Avatar
Re: paint code ?
Daniel, check the glove box sticker on that 02 'sub and start looking for any 3-digit codes that end in 'U' or 'L' . (that stands for Upper & Lower.) If you can find two codes that match, that are numbers in the first two spots (like 29L & 29U ) that will be your code. Take that to any store that sells automotive paint and they should be able to mix it for you.
bigben is offline   Reply With Quote
Old 04-09-2007, 10:00 AM   #4
Jonboy
Slots go on anything!
Re: paint code ?
On that same sticker, look for the WA number. It will be the bottom line on there, and will be followed by BC/CC (Basecoat/clearcoat). That is the number the paint will be mixed from, the top color will be first.
