04-10-2007, 03:17 AM | #1 |
True Addiction
Getting Started
Here are a few pics of my progress, its going pretty slow.
04-10-2007, 03:30 AM | #2 |
Re: Getting Started
Hello it looks good good luck with it
nickle and dime |
04-10-2007, 03:39 AM | #3 |
True Addiction
Re: Getting Started
Thanks royo
04-10-2007, 11:40 AM | #4 |
Junior Member
Re: Getting Started
Maybe it is the image but it looks like your notches are sitting at two different angles...?????
04-10-2007, 03:15 PM | #5 |
Re: Getting Started
That's the KP notches, they look funny in every picture because of the bend. They match up well, but I have to do a double take every time I see them too.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-10-2007, 06:01 PM | #6 |
Yellow truck club
Re: Getting Started
I think that has shown up in other frame pictures as well. They do look proportionally different but it is just an illusion..
Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
04-12-2007, 05:31 PM | #7 |
True Addiction
Re: Getting Started
There on straight according to the tape measure. I do have a bit of an issue. The front mounts on my four links need to be further away from the frame (the front is norrower then the rear, because of the frame being tappered.) Im planning on build a small steel box (about an inch) to allow the bars to be perfectly straight. Can anyone offer any tips or perhaps some good pics? Thanks, any other suggestions would be great as well.
04-12-2007, 07:11 PM | #8 |
Re: Getting Started
when you are done and if you feel like the front still isnt low enough.. you can take off the upper bag plate and put in a spring cup up top so the bag sits inside the crossmember... frame looks good!
04-12-2007, 07:13 PM | #9 |
Re: Getting Started
check out this link for the 4 link issue.
http://67-72chevytrucks.com/vboard/s...highlight=link I did the same thing but sliced a piece of 2x4 box tubing. Here is a pic, but not a very good angle. The first pic is from the above link. There are a lot more in the actual thread. |
04-13-2007, 03:34 PM | #10 |
True Addiction
Re: Getting Started
thanks guys, any sure way to get the proper yoke angle? Im planning on running it 4 degrees down. Please tell me if this is wrong, Thanks again
04-13-2007, 03:41 PM | #11 | |
Re: Getting Started
From what I've read/heard, the pinion angle should be 2-4 degrees and should be pointed in the opposite direction of the trans. tail shaft, but at the same number of degrees. For example, if your tail shaft is pointing down at 3 degrees, then your pinion should point up at 3 degrees. |
04-13-2007, 04:10 PM | #12 |
someday it will be done!
Re: Getting Started
This was a pretty good read I thought. http://www.airridetalk.com/articles/...-joint-enigma/
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
04-13-2007, 06:14 PM | #13 |
Junior Member
Re: Getting Started
yes .... that is correct.... your pinion angle needs to be the exact reflection of the trans tailshaft.... if it is at -3.5 then you want you pinion at +3.5 ect...
04-13-2007, 08:55 PM | #14 |
Re: Getting Started
Jlaird, how long are your 4-link bars?
04-17-2007, 09:39 PM | #15 |
True Addiction
Re: Getting Started
Hey BedSled71, you dont have any good pics of the front bags mounted without using the plate do you. I thought about trying that, thought I might get an inch or so, but wasnt sure how to go about it. Thanks for the help.
04-17-2007, 10:03 PM | #16 |
Re: Getting Started
sorry Scoti, didn't see that. They are all 32"
04-30-2007, 12:35 AM | #17 |
True Addiction
Re: Getting Started
Here are a few pics of what I got done yesterday. Pics are kind of small, this site is hard to upload large pics. Anyone have any comments on my progress
05-11-2007, 01:34 PM | #18 |
True Addiction
Re: Getting Started
Few More
05-11-2007, 02:01 PM | #19 |
Re: Getting Started
Looks Good!! I'm going with the front setup like you and the ART rear setup for my 72..
Mike 1972 LT1/4l60e Short Bed ART Front and Rear Strong Arms http://www.67-72chevytrucks.com/vboa...50#post2151750 |
05-11-2007, 02:12 PM | #20 |
Re: Getting Started
i like what im seeing!!
05-11-2007, 02:12 PM | #21 |
Ever heard of Beech Island??
Re: Getting Started
Thats very cool. Nice work.
05-11-2007, 02:26 PM | #22 |
Re: Getting Started
WOW thats not z ed and its on the ground do anything to the body looks good
nickle and dime |
05-31-2007, 03:49 AM | #23 |
True Addiction
Re: Getting Started
Hey guys, Im having trouble fitting my panhard bar on. It's the one that comes with the universal parallel 4-link kit from KP. I'm running out of room in between the axle and the notch. Any suggestions?
07-23-2007, 05:49 PM | #24 |
True Addiction
Re: Getting Started
Well, I just ordered a Poterbuilt X member, Cant wait to get it !! I've got all the rear suspension done except for the panhard bar. I installed a kit from Kp components and there is simply not enough room for it to fit between the rearend and the frame (when dropped). I think the only way to solve the problem will be to run some type of Watts link. Has anyone installed one of the "totally polished" ones? Thanks for the help guys.
Ben |
07-23-2007, 06:52 PM | #25 |
Re: Getting Started
Bigshoe24,
Your truck is looking good! It's going to look even better with the dropmember! Kp components sells watts links cheaper then Totally Pollished. What rim and tire do you plan on running? Again lookin good! Tony from Norcal |
