Old 05-26-2007, 12:39 AM   #1
13lazer
13lazers' blazers
13lazer's Avatar
head gasket advice?
i developed a sudden missfire and power loss a few weeks ago. i have been tuning up every bit of my 383 stroker engine with no improvement. today i noticed a lot of water in my exhaust and bubbles in my oil. my motor has between 30000 and 50000 miles on it and i ride her hard. i have been advised that changing head gaskets will cause another part of my engine to fail. the motor ran flawlessly until recently. can i get away with simply changing head gaskets or will i have to swap out the cam, rings,... what are the chances that i can save my engine?
1970 2wd blazer
1972 1ton blazer 4x4 in progress
1966 mustang coupe (modified)
1985 c20 suburban tow rig
1996 462 ranger with a 150 efi merc. a former B.A.S.S. tournament boat
almost all exempt from california smog laws intentionally.
13lazer is offline   Reply With Quote
Old 05-26-2007, 07:07 AM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: head gasket advice?
Never heard the "Changing the gaskets will make something else fail" scenario?
But then again I'm not a Motorhead, I can't see why you couldn't do just them.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 05-26-2007, 12:54 PM   #3
jhow66
jhow66's Avatar
Change the gaskets.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-26-2007, 01:12 PM   #4
Jtrux
I'm a poor spectator
Jtrux's Avatar
Originally Posted by jhow66 View Post
Change the gaskets.
agreed
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-26-2007, 02:15 PM   #5
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
If the miss IS from coolant getting into a cylinder, the top of the piston will be clean. Pull the spark plug on the suspect cylinder, turn the crank until you can see the piston thru the spark plug hole. If it is covered in carbon like the others, not a head gasket. Antifreeze in the oil destroys the bearings, it bonds to the bearing material. If the oil doesn't look like chocolate milk, you are probably ok. An oil change with a can of motor flush will "cut" the antifreeze from the bearings, if you do it before damage is done.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 05-26-2007, 02:53 PM   #6
Joes69c10
Proud Father
Joes69c10's Avatar
Joes69c10 is offline   Reply With Quote
Old 05-27-2007, 01:03 PM   #7
13lazer
13lazers' blazers
13lazer's Avatar
thanks for the advice, i'll just pile on another project. i'll come back if i hit another problem im not sure about.
1970 2wd blazer
