Old 06-12-2007, 10:13 PM   #1
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
How- to: Modifying the firewall for Caddy engine clearance in a 4x4
If you want to put a Caddy engine in a 4x4 without moving the transmission forward, here's how I do it. This is what i have found to be the easiest way. Moving the engine forward creates it's own problems (engine crossmember has to be moved forward, "big" oil filter won't clear, exhaust manifolds won't clear the frame rails with the engine positioned correctly for the fan shroud, etc). with the engine in the "stock" location, you can't use the mechanical style gas pedal. There isn't room to clear the cylinder head. Even with the cable- style pedal, the three nuts welded to the firewall won't clear the head. The first one I done years ago, I just hammered that area down about 1/2" and cut out the clutch rod hole & welded in a pocket for head/ exhaust manifold clearance. Even with a 3" body lift, it won't clear without doing this. This time, especially since I'm using a '69 cab, I am going to remove the pedal area & recess the area another 1/2". This will also give me a clean slate to install the gas pedal just where I want it.
I can see where this same mod would work good for a BBC or diesel conversion.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 06-12-2007, 10:20 PM   #2
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: How- to: Modifying the firewall for Caddy engine clearance in a 4x4
thats a big hole, looks good so far
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-12-2007, 10:20 PM   #3
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I trim the panel to the rough shape & size, but leave a little extra all the way around. Then I tack it in place, then cut/ grind for a nice fit.
Old 06-12-2007, 10:27 PM   #4
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Be sure the firewall insulation is pulled back & secured good- it is VERY flammable. Ya need not ask me how I know!
Old 06-12-2007, 10:35 PM   #5
JAKES 68GMC
Aluminum slot wheels rule...
looks good, nice job.
JAKES 68GMC is offline   Reply With Quote
Old 06-12-2007, 10:38 PM   #6
GREASEMONKEY72
nice work
-steven
Alte Seele S.S.
Old 06-17-2007, 11:13 PM   #7
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Thanks for the complements! Here's some progress pics. I pulled off the 36" hummer tires & put on new 33/12.50/16.5 BFG AT KO's this weekend too
Old 06-18-2007, 12:46 AM   #8
Southedisto
River life......
Southedisto's Avatar
Nice work, looks almost factory.
Southedisto is offline   Reply With Quote
Old 06-18-2007, 12:50 AM   #9
1969k10stepside
Nice mod,and I agree,it looks almost factory.Are you going to eliminate the body lift on it when you finish swapping the body from the donor 2wd? I'm not a fan of the BFG All Terrains because gravel tends to get stuck in the tread but those tires look better on it than the previous hummer tires!
1969k10stepside is offline   Reply With Quote
Old 06-18-2007, 01:19 AM   #10
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Yeah small rocks and gravel can be annoying with them. But I plan on alot of road time with this truck (at least in comparison to the 15k miles or so I have put on it since 1995. Hopefully they will last awhile. The cheapest mud radial I could find was a generic for $180 a pop. I got these for $140 each. The rims have quite a bit of dish to them- I think I need the body lift to keep them from rubbing in a bound- up turn. I also have another complete engine I have been collecting parts for a buildup. Arias forged 10.5 pistons, 7" Olds rods worked over, big valves & '70 heads, a 460 intake & adapter, etc. Std. headers would be a botch job at best, I think modified 460 fenderwell exits will be the way to go. The body lift will make that easier.
If I can pull it off, I'll have the new 514 Caddy done next year
Old 06-18-2007, 01:27 AM   #11
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
I think the stance looks mean from the front
Old 06-18-2007, 01:40 PM   #12
Yukon Jack
Post Whore
Yukon Jack's Avatar
Your mods look great.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-25-2007, 02:03 AM   #13
Duallie
Duallie's Avatar
I "massaged" the tunnel out to the hole for the clutch rod, welded it shut, and left the brake booster reinforcement alone. I have 1/4" clearance between the corner headbolt and the firewall. I used a cable throttle pedal, too.
I also clearanced the top of the framerail for the passenger side exhaust manifold.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
