Old 07-02-2007, 12:50 AM   #1
ocbaud
Garage Queen Material
help with heater controls
alright, look at this picture and tell me about it
this controls the door to the blower and heater and stuff. the only problem is, i dont see what controls it... if the blower is on any setting, it will blow a little out of the vents and mostly out of the bottom. if i move this thing manually to the left, it will stop blowing from the bottom and blow out of the top vents in the dash....
ocbaud is offline   Reply With Quote
Old 07-02-2007, 01:38 AM   #2
ocbaud
Re: help with heater controls
alright, looked at it some more. i guess the door is vacuum operated. well, if you look at the VERY bottom of my picture, you will see the little off white thing on the door. well its broke and not attached to the door anymore.... so the vacuum wouldnt pull it open or shut.
even though that is broke, switching between positions on the switch(heat, ac, vent, defrost) the arm doesnt move at all.
does anyone have a full diagram of how the vacuum lines should be for the heater/ac crap?
thanks
Old 07-19-2007, 05:12 PM   #3
ARAMP1
ROCK*STAR
ARAMP1's Avatar
Did you ever get this fixed? I think mine is doing the same thing.
ARAMP1 is offline   Reply With Quote
Old 07-20-2007, 03:19 PM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
Eric is that looking up into the dash or straight ahead at the firewall?, thinking this might be whats wrong with my AC not blowing cold air at idle as stated in my previous post on R12/R134 conversions
Malo83 is offline   Reply With Quote
Old 07-20-2007, 10:46 PM   #5
ocbaud
fire wall
i had to replace the plastic tab that was broken. $2.xx part at gm
Old 07-21-2007, 12:04 PM   #6
crossy
Oh,you can't buy that new
crossy's Avatar
you said the door was still not working? there is a small vacuum line that goes through the firewall to the engine side and that is where the switch gets it 'feed' from. BE SURE you have full vacuum to the switch itself at the control panel. I have seen those vacuum lines collapse because of so many years in the engine bay.
go from there. crossy
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
