Old 09-29-2002, 08:45 PM   #1
70 3/4T beast
Replacing C-20 HD springs
I have a 70 C-20 with HD springs in the rear. The ride is extremely bouncy. Since I am going to replace the trailing arms, I wanted to replace the springs as well. Can I put standard 1/2 ton springs in? The truck currently sits higher in the rear. Would the 1/2 ton springs level out stance and improve the ride? Any input is appreciated. It has helper springs, too, but it has seen about the last of it's heavy hauling days.
1970 C-20 longbed, 350, vortec heads w/4 spd and a 4:10 rear. We call it "The Beast."
70 3/4T beast is offline   Reply With Quote
Old 09-30-2002, 10:35 AM   #2
slam33
slam33's Avatar
If it's bouncy, you should be looking at the shocks. Yes you can use 1/2 ton spring but you loose the load capacity and ride height. I have a 1/2 ton and I'm running 3/4 ton springs
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 10-16-2002, 04:48 PM   #3
COBALT
COBALT's Avatar
Yeah, my ride in my 3/4 ton was bouncy, and after pulling the shocks I realized why. They were blown. Toast.
New bushings in the trailing arms + some new shocks and hardware and it should be just fine.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
