Old 05-01-2002, 10:39 AM   #1
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Post Swap a 71 front end to a 67
So, what would it take? Does everything on the front clip change? Fenders, Hood, Radiator support, what about AC items? I have a 71, but I love the looks of the 67 front end.
2001 GMC 2500HD Crew Cab Duramax, Allison, 4WD, Love it
1971 Chevrolet 1/2 ton 2WD Short/Step Side. In process of frame off restoration
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-01-2002, 10:44 AM   #2
Desert Rat
Desert Rat's Avatar
Post
I would unbolt entire clip(dont forget to disconnect wires and battery,and id lift off the 72 nose and stick a 67 one on,simple as that.i believe only interchangeable parts are hood hinges,battery tray,and inner fenders.
Desert Rat is offline   Reply With Quote
Old 05-01-2002, 11:16 AM   #3
1971Stepside
Almost Satisfied
Post
So the radiator support and all will work? I just need hood, fenders (outer), and grill? That almost sounds too easy.
Old 05-01-2002, 11:18 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
If you don't already have the tin lined up, you oughta think about a '86 front clip. It'll have the side marker lights that your bed has.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 05-01-2002, 11:21 AM   #5
Desert Rat
Desert Rat's Avatar
Post
need a 67-8 core supprt,67 Chevy or GMC fenders,67-8 hood,67-8 grille,filler panel and latch,
the 67-72 inner fenders,hood hinges,battery tray are the ONLY pices the same im aware of,that you can use,you cant use your fenders,hood,-maybe core support,if modified????.
Old 05-01-2002, 11:25 AM   #6
snow man
Post
if your going to do this swap i sure would be inerrested in the 71 fenders if they are good
snow man is offline   Reply With Quote
Old 05-01-2002, 01:21 PM   #7
1971Stepside
Almost Satisfied
Post
Your right Longhorn mail, the 68 would be best for the side marker lights! I am getting ahead of myself, but am on the look out for a parts truck and may want to pick up a 67 or 68 rather than a 71 or 72 for the parts.
I have a very good radiator support a very good right fender and a louvered hood for a 71. I really hate to give up the hood.
So, I am assuming AC radiator and such will bolt right up to the 67/68 clip?
Thanks for your help guys. I will do some checking and see what I decide to do. I will let you know on the parts I have available should I choose to do it.
Old 05-01-2002, 06:03 PM   #8
Fast68Chevy
Fast68Chevy's Avatar
Post
a/c amd aradiator are all same 67-72. will bolt on to all supports same way, only tihng differs on the supports is the headlamp bucket welded placement
sounds like you have some 71 sheetmetal to sell or trade off for 68
good luck
Fast68Chevy is offline   Reply With Quote
Old 05-01-2002, 07:12 PM   #9
snow man
Smile
put me first on list for right fender,would like to see the lovered hood would look good on my 71 longbed snowman
