09-21-2007, 02:12 PM | #1 |
A little cutting and welding on the Jimmy floor
The previous owner felt a need to cut a hole above the gas tank in the floor of the Jimmy. I can only guess he did it for access to the sending unit? The gas tank wan an aftermarket 30+ gallon tank that looks similar to those Northwest metal products tanks. I was having problems like I was running out of gas so I decided to put a repop tank in (after soldering a filler neck on). While the tank is out I decided to weld a patch in the floor. Here are a few pics of todays progress.
09-21-2007, 02:15 PM | #2 |
Re: A little cutting and welding on the Jimmy floor
The only problem I have is sometimes when I weld I have to gring to deep to smooth out the welds. Anybody have any suggestions? More weld?
09-21-2007, 02:25 PM | #3 |
Tot Roddin'
It looks great so far!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
09-26-2007, 05:10 AM | #4 |
Looks great wish i could weld body pannels. that 30 gal tank must be nice I hate having to fill up so much.
Earl 68 2500 4x4 GMC Burb |
09-26-2007, 06:41 AM | #5 |
Not really, it was starving for gas even at 1/2 tank. It was also installed poorly, tipped towards the back. I installed a repop tank that I soldered a correct fill tube on. Tank and all hoses are in. I am filling it today, we'll see if I did a good job.
09-26-2007, 06:43 AM | #6 |
Good luck I hope it turns out good the patch work looks great.
10-14-2007, 11:59 AM | #7 |
Here is the gas tank install. I used the aftermarket straps (I welded the folded over ends) and undercoated all of it, straps included before installation. I also did all the body mounts at this time, painting everything metal with POR 15 before mount install.
