duramax?
It would be so so so sweet. After i get this corvette done, do i dare atempt? duramax in a blazer? the duramax transplant is getting pretty popular in the diesel power mags. Just how hard would it be? If i do it, i plan on spending around 7000 - 8000 on the blazer, so i can concentrate on the engine swap rather than fixing rust. Please talk me outta this lolol.
If it don't lope...well...it sucks. |
Re: duramax?
You better get an Allison to match
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks ![]() |
Re: duramax?
its alot of work you would have to beef up the frame change to a one tone drive train.No one makes anafter market computer and wiring set up for it so you would have to spend hours working that out. if you can score last months diesel power mag somewere there is a 72 step side in it with a d-max. And unless you can score the parts for one great deal think more around teh 15k mark to do it. Thats why most guys go to the 6bt it alot cheaper and easier to do and you can get the same power.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-01-2007 at 03:40 PM. |
I'm a poor spectator
Re: duramax?
It would be nice but it sure would be expensive. Personally i'd rather go with a regular old gen 3 swap especially concerning overall price of the project.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
Re: duramax?
Im building a 6.2 for my burb so I can run home brew fuel. But I dont need the power of a d-max or 6bt.
Earl 68 2500 4x4 GMC Burb |
2WD Jimmy
![]() Join Date: Mar 2005
Re: duramax?
Also, I belive the Duramax and Allison come in at about 1400lbs!
Dont get me wrong, Ive got one in my truck (its great for towing and milage). But 1400lbs up front for wheelin? I dont think so. ![]() |
Re: duramax?
Been looking for a wrecked Duramax 4x4 to shorten the fram on. A body swap seems to be the easier thing to do, and you get IFS
'72 K5, known as 'the Fox.' |
Re: duramax?
I know that is one long engine trans combo It may be to long for a blazer.
Re: duramax?
good point. Anybody got one they can measure, say from front axle to the back of the xfer case?
Re: duramax?
Ill do it for you in the AM.
Re: duramax?
I have been thinking about this swap as well. I think you could use a built 480le behind the duramax, which would make it a little shorter. You can't beat the tourque the new diesels put out.
72 Blazer CST 383 stroker roller, fuel inj, t350,NP205, D60 front, 14b rear, detroit locker, 38 x15.50 mtz's, welds, cross over steering, custom cage,Line X Spray in liner, House of Colors Tangelo Pearl Orange |
Can't wait to retire!!
Re: duramax?
I can measure if needed.
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#13 |
Re: duramax?
Its a big combo 6ft 10 in ruffly from fan to tail shaft on the trancfer case. you may be better to go with a stick and build a nv4500 205 combo to put behind it.
Earl 68 2500 4x4 GMC Burb Last edited by earl87gta; 10-04-2007 at 10:59 AM. |
#14 |
Re: duramax?
This would be a way cool swap in a 67-72 chevy. It can be done but it will cost more than its worth.
#15 |
Re: duramax?
actuly I think if you got it done and had to sell it for some reason you would get you money back maybe not labor but parts cost I think you would get it back out of it.
#16 |
Re: duramax?
My buddy who I just told about this site is putting one into a 73 blazer (full removable top) He is boxing the frame and has to widen it by an inch. He is also doing on board air, welding and something else. He got a front end from an 87 sub with the four square lights. He fabbed in the vents from a trans am fender to get air to the duramax. He started with a very wrecked 2006 duramax he got at an insurance auction. It has been over a year and still going. Frame is finally ready. He is building a tank more than a blazer. Should be fun though. As for $$$ I am not sure but he is single and has a shop for "work" Not much for pictures yet but I'll see what he has and try to get them up. I have a 66 sb ss.
