10-18-2007, 08:12 AM | #1 |
Electric rear window
I have been contemplating running an electric rear window in my 72. I have just removed my cab off the chassis and I've popped the rear screen out. Origionaly I wanted just a rear slider but now decided to step it up a bit and turn it into a rear electric window. I will be relocating my fuel tank to the rear for some added clearence or I might just spacer it forward enough to clear the window mechanism.
Has anybody done this mod with sucess? I'm pretty sure I'll pull this one off but any pics always help. Thanks Glenn |
10-18-2007, 09:22 AM | #2 |
Senior Moment
Re: Electric rear window
You can buy it here. I have one in my truck and love it.
http://www.crlaurence.com/ProductPag...1.html?Origin=
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 10-18-2007 at 09:23 AM. |
10-18-2007, 09:29 AM | #3 |
67-72 Addict!
Check with board vendor WES. I bought a regular slider from him 3 years ago as he is a vendor for CR Laurence. He may be able to get the POWR- Slider. They retail for about $400. It sounds like you want a vertical slider though.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-18-2007, 09:29 AM | #4 |
Do you mean a rear window that rolls down into the cab?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
10-18-2007, 10:00 AM | #5 |
I remember seeing them in some trucks a few years back that had them, I think they were conversions though. The companies that put the aftermarket wheels on and spice up the paint a little and charge 10K more for the truck.
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
10-18-2007, 10:25 AM | #6 |
Someone (maybe two) has done this on the board. I'll try to find it but you can try a search.
10-18-2007, 11:05 AM | #7 |
I think someone did it using the stuff from a Tundra?
10-18-2007, 02:16 PM | #8 |
Self-proclaimed LED man
there was a mercury from the mid 60's that had a vertical rear sliding window. That might give you some ideas for doing one youself. Dont remember the model of car. Maybe someone knows the car im talking about.
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor Last edited by 724x4a/cchevy; 10-18-2007 at 02:17 PM. |
10-18-2007, 02:24 PM | #9 |
Questionable
One of the guys who has a shop here at the forum posted pictures of a show truck with a vertical slider. They didn't have any pictures of the guts to show us how it worked.
This thread/question comes up at least once every 4-6 months in this forum, but I have yet to see any real proof or evidence of how this is done, exactly. There are a ton of options - Toyota Land Cruisers have a rear slider in them, and so do a few other truck/SUV type vehicles. You could easily borrow from one.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-18-2007, 03:14 PM | #10 |
1970 Daily Driver
I got this picture a while back off of the forum and saved it for future referance.
He got an electric window regulator out of a 86 Chevy blazer. He narrowed the sash a little, cut out the pinch weld around the back window and welded in a window channel, cut out the back of the cab under the window ( just the inner peice above the gas tank) and added a 1" box to the back for the window to roll down into it, fabricated a custom stand to bolt the regulator to and then used a piece of custom tempered glass cut 3" taller than the factory glass. Thats all I have on it. If any one has more infromation or some good ideas of how to pull this modification off I would like to hear them. It would be nice to have some pictures of the internal workings.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance. |
10-18-2007, 03:15 PM | #11 |
5 maybe as much as 7years ago on the original show trucks back when stacey used to actually do stuff before he became a pitchman he did a sliding backwindow conversion that came in a kit but still required alot of fabrication// i've al;so known people who have used capricse guts(motor ,downlimit uplimitswitches sissorsassy aand bottom rail) out of a tailgate and fabbed up trhe tracks drain and other stuff// all the ones i've seen take up at least as much room as the original gastank some were even more bulky than that
10-18-2007, 03:15 PM | #12 |
for you people with the small windows you could probably get away with a kit from a honda del sol
they're pretty small and the rear window rolls up and down,. |
10-18-2007, 03:32 PM | #13 | |
VERY cool. I want to know how to do this. |
10-18-2007, 03:38 PM | #14 |
I have a honda del sol regulator that I'm going to use on my 61; small window. I'll post pics when I do it. Those regulators are cool. All cable driven and very compact, but only ~9" of travel.
10-18-2007, 04:27 PM | #15 |
I built myself a rear back window using the 86 blazer regulator. I have to relocate fuel tank and add a 1" box to the back of the cab. I haven't finished my project yet but the back window works. I had to fabricate a rear bracket to hold the regulator and you can see in the pics. Had to have a piece of custom glass cut also.
10-18-2007, 04:57 PM | #16 |
Thanks guys, Here in australia we have some station wagons that run an electric rear wind so I might just steal it out of one of the. I'm not too bad with the fab so I'll prob fab all new guide rails myself. I was thinking of either getting a new/larger rear screen made or actually closing up the whole and using the origional screen. I will keep you posted with my activities.
10-18-2007, 05:02 PM | #17 |
what about using one out of a 90ish bronco? theyre power and have pretty good travel
10-18-2007, 05:12 PM | #18 |
something like the top half should work, right?
10-18-2007, 05:16 PM | #19 |
toyota 4runners used sliders forever if you can understand the japanese engineering behind them
10-18-2007, 07:10 PM | #20 |
Lemme show you something!!
Yeah it's a mid-to-late 50's Mercury Monterey with the "Breezway" package. Very cool car, indeed. Now back to the question at hand. If I recall my Pop's mid 70's Buick Vista-Cruiser wagon had a power window in the rear gate....i'm sure there are other vintage "Land Barges" that also had a power window in the rear gate as well.
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
10-19-2007, 04:28 AM | #21 |
Was having a good look at my body today and I'm also going to remove the drip rail.
10-19-2007, 06:54 AM | #22 | |
Village Idiot....
10-19-2007, 07:43 AM | #23 |
still buypickupparts
the mechanical part on a toyota tundra sells new for $600. its a sissors action it looks like you get all the guts of it plus the motor for this price, wheres them toyota yards at
Its Gonna be a Great Day, I woke up this Morning. 72 SWB Fleetside freshly painted. putting a 94 LT1 with 700R4 tranny lowered 4 in the front 6 in the back 81 chevy half ton 350 89 Silverado 4x4 going ta church truck |
10-19-2007, 09:22 AM | #24 |
don't forget to incorporate a rain gutter in there todevert water from rain and washings that seeps past the bottom seal out of the cab before it reaches the carpet. it won;t be hard to do but is very much needed, it's not like a tailgate where you just put weep holes outside the seal
common sense isn't so common anymore |
02-10-2008, 03:13 AM | #25 |
this mod sounds great!!!!.............i would love to do this to mine.....need morte info !!!!
TIM '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
