Old 11-03-2007, 06:18 PM   #1
mike409
mike409's Avatar
flame throwers need help with hei for flames help
can't get it to spark every thing is hook up correct but is for points ign i have hei it is hooked up to the c- side of the coil but does not get spark to plugs in the pipes ? any body help
1995... 2DOOR TAHOE
1999... SUBURBAN 2 WHEEL DRIVE LOW RIDER sold!!
1999... SUBURBAN 4X4 sold!!!
1967...3/4 TON 4X4 SHORT BED 454 sold!!
1972...Cheyanne Super 454 1/2 lwb new toy!!
1972...1 TON 4X4 SUBURBAN
CHEVY "RULE" GO OLD SCHOOL!!!!!!
http://www.myspace.com/slicks72
mike409 is offline   Reply With Quote
Old 11-03-2007, 07:38 PM   #2
truckster
truckster's Avatar
Re: flame throwers need help with hei for flames help
I'm not sure if I understand the question, but I'm assuming you're trying to get an HEI to work. You need 12 volts at the BAT connection on the cap. The stock wiring has 6 volts going to the distributor, so you'll have to do a little wiring. The coil in in the distributor cap. If you have 12 volts to the BAT terminal and the other terminal from the distributor is plugged into the cap, and the timing is right, it should fire right up.
truckster is offline   Reply With Quote
Old 11-03-2007, 08:35 PM   #3
mike409
mike409's Avatar
no sorry i meant flames out the tail pipes it is a kit to blow flames off of raw fuel thanks but i got it lite now did not have anuff fuel going to it had to the choke up it is cool some people use propane big flames
thanks again truckster
1995... 2DOOR TAHOE
Old 11-03-2007, 08:57 PM   #4
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
usually the ignition system is shut off after revving up the motor. When you shut off the ignition, the spark plug in the tail pipe is supposed to ignite and burn the unburnt fuel as the motor freewheels before it comes to a stop. Eventually you switch the engine ignition back on and the motor fires back up. Mike, it sounds like you aren't killing the engine's ignition system and it's still burning the majority of the fuel and none of it's shooting out the tail pipe.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 11-03-2007, 09:01 PM   #5
chevy72blu
chevy72blu's Avatar
.... Or you could just seriously fatten up the AF mixture by going with larger jets in the front and back. You arent going to make any friends with the EPA but Ive heard of people doing this to achieve what you want.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 11-03-2007, 09:12 PM   #6
724x4a/cchevy
That's plan B!!!
My LED Website
I also do LED:
-Third Brake/Cargo
Norwood Survivor
Old 11-03-2007, 09:19 PM   #7
Twistedsteel
Twistedsteel's Avatar
You should get someone to take some pics and then post em.
Albie
Twistedsteel is offline   Reply With Quote
Old 11-04-2007, 02:19 PM   #8
mike409
mike409's Avatar
you got it !!!! yes i have it working great its kool i have manual choke and i set it were i can still rev it about 2500 and hit it and it will throw it about 6 to 8'
its bad ass
ill get some pics tonight!!!!!!
1995... 2DOOR TAHOE
Old 11-04-2007, 03:03 PM   #9
chev74
Addicted to Chevy
chev74's Avatar
mike, which kit did you buy? i have been wanting to do this for a ong while and i was wondering how much you paid and if it really does work. i have a holley carb with electric choke... btw
chev74 is offline   Reply With Quote
Old 11-04-2007, 03:42 PM   #10
fun in dirt
fun in dirt's Avatar
That sounds sooo cool! (Daydreaming...) I can picture it now melting the rubber window molding off that Fast n Furious junk at the stoplights
Pictures, Pictures, We Want Pictures!!!!!!!!!!!!!!!!!!!!!!!!!!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 11-04-2007, 04:33 PM   #11
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
i used to do this with my 77 step side, with full 3" dual exhaust.
nothing cooler than cruising under a bridge, turning off the key, coasting, then turning it back on with a BANG!
IvelDesigns is offline   Reply With Quote
Old 11-04-2007, 06:27 PM   #12
Premium72
Premium72's Avatar
had a home made kit on my 49 coupe pretty cool althought that lil 6 wouldt shoot 6foot flames. be prepaid to change your oil pretty often deppending on how much you do this. some of the unburnt gas will get down in the oil an wash the cylinder walls, and can mess up a perfectly good engine. good luck.
Premium72 is offline   Reply With Quote
Old 11-04-2007, 09:42 PM   #13
mike409
mike409's Avatar
the kit is xtreme flame kits www.flamekitz.com it work great i just got home from going to dinner and tried a few different things i gotter now my truck is about 4 feet to bottom of the rocker to the ground and my pipes come out in front of the tire and it is 4 inch it will throw a 6 to 8 foot flame when i use the chock thats when it works the best it is time to cook some rice but some times it will back fire and make your ears ring with the windows up thats pretty loud hope i dont hurt the motor but ill watch that and change the oil when i get wild LOL...........
1995... 2DOOR TAHOE
Old 11-05-2007, 02:10 PM   #14
pmpski_1
pmpski_1's Avatar
pics pics pics!
pmpski_1 is offline   Reply With Quote
Old 11-05-2007, 02:23 PM   #15
mvfd70
mvfd70's Avatar
yes. we want pics
1978 Chevrolet Silverado 3/4 ton 400 small block.
2000 F-250 Powerstroke
2002 GMC Yukon Denali XL
mvfd70 is offline   Reply With Quote
Old 11-05-2007, 03:22 PM   #16
LONGHAIR
Some punctuation might help too.....that is very hard to read
LONGHAIR is offline   Reply With Quote
Old 11-05-2007, 03:35 PM   #17
mike409
mike409's Avatar
Did not know we were getting "graded" on this project!!!!!..........LOL!!!!!
1995... 2DOOR TAHOE
Old 11-05-2007, 04:07 PM   #18
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Pics are great, but vids are better !!!!
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 11-05-2007, 04:19 PM   #19
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Try this...always brings a smile to your face!
http://www.youtube.com/watch?v=Zk2ixe3xlQI
and this...
http://www.youtube.com/watch?v=1mwM7da0q0c
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 11-05-2007, 05:30 PM   #20
mike409
mike409's Avatar
now thats cool an old flat head at that every body should look at that !!!!!
1995... 2DOOR TAHOE
Old 11-05-2007, 07:09 PM   #21
chev74
Addicted to Chevy
chev74's Avatar
i like this one
http://www.youtube.com/watch?v=kkPeJRiBSc0
the flames sound awesome
Old 11-07-2007, 01:24 AM   #22
chev74
Addicted to Chevy
chev74's Avatar
ttt. anyone else have good luck with flame kits?
Old 11-08-2007, 11:46 AM   #23
Lemield
Lemield's Avatar
I've got a kit on my 70 CST....works great. I can shoot a 2-3ft flame....great for tailgaters.....really.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 11-08-2007, 12:04 PM   #24
chev74
Addicted to Chevy
chev74's Avatar
what kit do you have?
