11-22-2007, 12:21 PM | #1 |
67 E-brake removal
Good morning everyone from the great white north. I noticed that my e brake is seized. The front cable fom the handle through the fire wall and the frame is stuck. I'm not sure how to remove it. where it goes through the frame? any suggestions?
1967 GMC Fleetside. (Betty) 1985 Chevy Shortbox 4X4.(Freddy) |
11-22-2007, 06:41 PM | #2 |
Who's got steelies?
Re: 67 E-brake removal
Hello,
these pictures should help: where the cable goes thru the frame cable clip on the frame in wheel well backing off the equalizer nut cable where it attaches to hand lever new cable where it goes thru frame I thought I had some of the new cable after installation, but I don't. The easiest way to remove the old cable at the frame is to break off the little spring fingers. Hope that helps!
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel Last edited by oldgold70c10; 11-22-2007 at 06:43 PM. Reason: so pictures would show |
11-22-2007, 07:36 PM | #3 |
Thanks for the great pictures and info. Very very helpful. Wasnt to sure how it came off. Thanks for all the help Ireally appreciate it.
07-03-2022, 12:34 PM | #4 |
But Found Her 25yrs Later!
How do you hold down all those clips at the same time to get it out of the hole in the frame?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
07-03-2022, 12:52 PM | #5 |
Use a small hose clamp to compress the fingers when removing .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-03-2022, 01:06 PM | #6 |
Great! I was also thinking of sliding a nut that is just the right size over it.
07-03-2022, 08:31 PM | #7 |
Yep, hose clamp worked. Thanks
