Old 10-10-2002, 02:41 PM   #1
backinblack
where can I buy a flip kit?
I have searched the archives, and am STILL looking for a good place to buy a flip kit and c-notch kit for the rear, and drop spindles; all for a 71 GMC C-10. Please advise!! Also, I want to replace the ball joints, tie rod ends, etc., and wondered if it is better to try and find an entire front end kit, or just buy individually from the local auto parts store.
Thanks in advance!
Oh, I know the rear stuff can be fabricated, but I would rather just spend the money and buy pre-fabbed, as my time is rather limited.
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 10-10-2002, 05:32 PM   #2
Primered_69
Primered_69's Avatar
That would be two of us that are looking.
1969 Chevy LWB - with shaved handles; 3 1/2 front/ 5 1/2 rear drop; (waiting to be put back together)
Primered_69 is offline   Reply With Quote
Old 10-10-2002, 07:13 PM   #3
Alexis
Member since 2000
Alexis's Avatar
Early Classic or bell tech should have them. if you have a welder and a torch/plasma cutter you can make you own. But i've installed plenty of belltech flip kits so i'd hit them up first.
Alexis is offline   Reply With Quote
Old 10-11-2002, 11:45 PM   #4
backinblack
To answer my own question, and for the benefit of Primered69,
NO ONE really makes a "flip kit", and so you will need to go to a trailer manufacturing shop, and buy a saddle for a three inch diameter axle housing. You can just use everything else from your existing setup. As far as the C notch goes, just order one from Classic Industries. Yeah, they're 128.00, but go out and get some good 1/4 inch steel and see how much fun it is to fabricate a GOOD looking and structurally accurate bracket. I don't know what your time is worth, but for the few hours it will take, I'll just buy it.
Also, the front end components can be had at the local parts store for far less than I could seem to find them as a kit from anyone. Of course, I don't know ALL the places to check, I was hoping to get a lead on that, but most kits I did find were 350.00 and up.
Anyway, this is what I have found.
Good Luck.
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 10-11-2002, 11:46 PM   #5
backinblack
By the way..... Belltech said they don't make a flip kit for a leaf sprung truck.
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 10-11-2002, 11:47 PM   #6
backinblack
......................Wishing more and more I had coils.
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 10-12-2002, 10:22 AM   #7
73GMC
Proud American
Question coil spring rear?
Dont' the 69-72 use COIL rear springs with trailer arms????
If you do use leaf springs, DJM suspension has flip kits as do Belltech. You could use the 73-87 version, no problem.
summitracing.com has them plus free shipping.
backinblack: Belltech lied to you.
BEL-6850
Vendor: Bell Tech Inc.
Product Line: Bell Tech Rear Flip Kits
Material: Steel
Finish: Powdercoat
The right way to lower your truck.
Chevrolet/GMC: 1973-87 C-10/C-15 ton pickup, 6 in. rear axle flip kit
This Bell Tech Flip Kit relocates the rear axle on top of the leaf spring pack for the lowest drop anywhere. The kit includes C-sections, welded saddles, spring plates and shock extensions. This kit will lower the rear of your vehicle 6 in.
Sold as a kit.
Also, DJM Suspension offers a kit too, available at summit.
63-72 Chevy c10
FK1012-5
5" Rear Flip Kit - 2-¼" Springs Only
DJM-FK1012-5 is the part number at summit.
73GMC is offline   Reply With Quote
Old 10-12-2002, 02:26 PM   #8
backinblack
Thank you!!!!
Yes, Belltech lied. They swore they had nothing to fit my truck, because I kept insisting they did from what I gathered on the internet.
Oh well.
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 10-12-2002, 04:36 PM   #9
Alexis
Member since 2000
Alexis's Avatar
i was about to throw a fit about that. thanks 73GMC i knew i wasnt going crazy. its only been six months since I installed a belltech flip kit. i totally forgot about DJM. they have some cool items for descent pricing.
Old 10-18-2002, 03:02 AM   #10
blowermtr
steering components
as far as the from steering components, just go pull an assembly from a junk yard. From a newer truck you will have to put diff. ball joints in which come cheap from a local parts store. If you are going lower and using a newer spindel out of a salvaged 73-86 rather than doing it right, you don't have to pull the whole upper and lower control arms. On the one you want to drive you will need to shim the upper control arm to fix the camber.
Mike D
67/68 slammed, blown C10 so close
blowermtr is offline   Reply With Quote
Old 10-31-2002, 11:05 AM   #11
Kopper
Just another source for lowering components...Performance Suspension Components. I have made several purchases from them and they were pretty good to deal with. Most of their lowering components are Western Chassis.
Flip kit page.
http://www.performancesuspension.com/TruckLowerTwo.htm
Ken
Kopper is offline   Reply With Quote
Old 10-31-2002, 10:06 PM   #12
78SilveradoSWB
78SilveradoSWB's Avatar
Another source is Stylin Concepts for DJM flip kit. I got one from them and it includes the shock extenders. At the same time I got a 3" DJM drop spindle, all for $279 and lucky me, free shipping!
78SilveradoSWB is offline   Reply With Quote
Old 11-07-2002, 05:55 PM   #13
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
Talking
well im a 73-87 guy so i dont know how much of this will apply to you guys but perfomance suspension technologies as well as performance suspension components make new suspension kits. they have websites but i cant remember exactly what they are. you can also get them with polyurethane bushings rather than the stock rubber. i bought my front end rebuild kit from pst and my spindles from psc(they sell western chassis, excellent stuff) hope that helps.
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
