Old 11-29-2007, 09:08 PM   #1
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Recalls
Where can I find all the recalls on my 03 SS?
westbrookw is offline   Reply With Quote
Old 11-29-2007, 09:32 PM   #2
WLPTMP
Active Member
WLPTMP's Avatar
Re: Recalls
call your local dealer or give me your last 8 digits of your vin and i can tell you if anything is open on it
WLPTMP is offline   Reply With Quote
Old 11-29-2007, 10:01 PM   #3
westbrookw
westbrookw's Avatar
Re: Recalls
31370729 And do you know what that sensor is above the drivers head. Making a sound like a compressor. Nothin going right with this truck.
Old 12-01-2007, 06:31 AM   #4
WLPTMP
Active Member
WLPTMP's Avatar
Re: Recalls
no open recalls
can you take a picture of the part you talking about
thanks
Old 12-02-2007, 11:47 AM   #5
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: Recalls
It's an aspirator. It senses the temp. inside the truck.
From SI2000:
Condition/Concern:
Customers may comment that they have a buzz or vibration noise emanating from the headliner in an area that looks like a microphone or a small speaker.
Recommendation/Instructions:
The plastic escutcheon grill, which is round and about the size of a half dollar and located just above the driver to the left, is the interior ambient temperature sensor. The sensor is used in conjunction with the automatic HVAC (C68). On occasions, this sensor has been known to make a buzz or rattle sound. The sensor uses a small fan to pull air over the sensor. This buzz noise may be intermittent.
Although it may not be possible to alleviate all of the buzz or noise from this sensor, Engineering has found that if the sensor is installed incorrectly that it may bind and cause the fan to make a buzz noise. Remove the sensor and while doing so check for any binding. Reinstall the sensor and re-test. If the noise is still present, the sensor itself may be noisy and require replacement.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
