Old 01-22-2008, 08:18 PM   #1
NP241 RH/LH Differences?
How interchangeable are NP241C cases?Can I take an NV4500/NP241 LH-drop and just bolt an NP241 RH-drop in it`s place?How about any differences in an NP241 from behind a 4L80E and one from behind an NV 4500?
Old 01-28-2008, 05:16 AM   #2
bigtruck81
Re: NP241 RH/LH Differences?
both should be 32 spline, prividing you have the proper adapters for the 4500, this shouldnt be a problem.
bigtruck81 is offline   Reply With Quote
Old 01-28-2008, 06:13 AM   #3
FormerMember
Where is the NV4500 from?
1 ton Chevy should be 32 spline output
Dodge output is 23 or 29, I think...both should be the round 6 bolt pattern. I have several 241's here, as well as a 271 from behind a Chevy NV4500.
I think the GM NV4500 and 4L80E use different length output shafts, but it shouldn't be too hard to make a spacer if required.
FormerMember is offline   Reply With Quote
Old 02-17-2008, 09:43 PM   #4
Here`s some better info.Thanks so far.
Truck#1:
`92 GMC K3500 SRW 6.5TD NV4500(solid flywheel) NP241 4.10
Truck#2:
`91 Chevy K(R/V?)2500 Suburban 6.2 4L80E NP241 4.10
Old 02-17-2008, 11:55 PM   #5
boostat4500
I know the newer 4l80e trannys are clocked as far as how the t-case bolts up. Meaning it can only go on in one spot, the studs are not symetrical all around. If the older one's, like yours, are the same way, I don't think you could swap between a left and right hand drop without the front output being in a really weird spot. Hope this helps some.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
