Old 01-28-2008, 12:21 PM   #1
drbyrdman
drbyrdman's Avatar
327 serpentine belt
I would like to run a serpentine belt setup on my 327. Does anyone know were to get one? I have a stock 327 with Fuelie heads. No assy. holes. Has anyone drilled Fuelie heads to do that?
drbyrdman is offline   Reply With Quote
Old 01-28-2008, 10:43 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 327 serpentine belt
dont drill holes in double hump heads! you go straight into water jackets, and will leak till the day you die. jegs has a few setups that completely bolt onto the waterpump mounting holes, too rich for my blood, i think they are around a grand.
brad_man_72 is offline   Reply With Quote
Old 01-29-2008, 09:11 AM   #3
Mick72K2500
GM Performance has a conversion kit that isn't that badly priced. Includes new accessories too. Without A/C, I have seen them priced around $550. Summit and Jeg's has them.
I believe the mounting system mounts to the water pump bosses.
It doesn't matter which way you are facing, as long as you are going in the right direction.
Mick72K2500 is offline   Reply With Quote
