PROJECT 7DEUCE
![]() Join Date: Dec 2002
Hydroboost question.
Can I run hydro boost on my truck if I am already running a hydro assist steering? Seems like it would max out the stock chevy pump??
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Hydroboost question.
if i think what your asking is " can i have power brakes and steering off the same power steering pump?" then the answer is yes. thats the way its made to work. if its a hydro boost pump, booster, and maybe even steering box.
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
PROJECT 7DEUCE
I have a west texas off road hydro assist on my cross over steering. My box came from them also the pump is just a standard chevy unit I was just wondering if the chevy hydroboost would be too much since I am already running a ram on there.
I run p.s. , hydroboost, and a 12000lb hydraulic winch off my gm ps pump.
PROJECT 7DEUCE
Thanks pumpkin thats what I wanted to hear....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 01-29-2008 at 11:23 AM. |
Everything is work in progress
![]() Join Date: Apr 2006
Thanks pumpkin ; ) LOL
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
![]() Join Date: May 2007
I've heard that ps pump off of a diesel works the best.The valve is different, its made for low rpm witch is what most people using hydro steer need.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
From the research I've done the saginaw pumps are all basically the same. The difference is in the preasure releif, and flow gpm. The diesels just use a larger diameter pully to offset the low rpm of the diesel.
one thing to think about is using a P/S cooler........pressure shouldn't be a problem but heat will be, plus you will probably also need a reservoir
What year model hydro boost bolts right in for the 1st gen trucks? (72)
I don't think there is a bolt in. I took one from an 87 and made the firewall bracket fit, then redrilled a hole in the brake pedal, this took a couple of tries to get the feel and stroke right. Will be doing another one soon out of an 89 p.u.
#13 |
MY diesel sub has a remote resevoir, but otherwise the pump looks the same.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars ![]() |
#14 | |
Post Whore
![]() Join Date: Feb 2000
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
