Old 02-02-2008, 04:40 AM   #1
1974k5blazer
I dont like it when its loose and sloppy!
Hey guys the steering on my 74 is rediculusly loose, what causes this and how do i fix it? what should i look for? its got a 4 inch lift and power steering?? need help have to drive it back to az soon and can't do that till i fix the steering, just keeping it on the road is a quite the task!
1974k5blazer is offline   Reply With Quote
Old 02-02-2008, 07:50 AM   #2
abebummy26
abebummy26's Avatar
Re: I dont like it when its loose and slopy!
Idler arms maybe tie rod ends is a possibility as well.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 02-02-2008, 07:07 PM   #3
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
What Guy Does???
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 02-03-2008, 12:29 AM   #4
Zoomad75
K5Camper
Zoomad75's Avatar
Well, I'd check out the ends on the drag link, tie rod and the steering gear itself. Other causes could be sloppy ball joints on the axle or (and this is often overlooked) a cracked frame at the steering gear.
If the frame is cracked there, every time you turn the wheel, not all the movement is going to the tires, some of it is flopping the gear around. Could be only a little or could be a lot. Have some body steer the truck with it parked while you watch for the gear assembly to move or not. If it's cracked you will need to fix them and add in a weld in brace.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 02-03-2008, 03:11 AM   #5
1974k5blazer
yeah looked at the gear box right after i posted this and its got three cracks around each mounting hole!! grrrrrrr something else to fix on this truck! anyone want to buy it for 2200!
Old 02-03-2008, 06:52 AM   #6
abebummy26
abebummy26's Avatar
Ok If your frame has not yet done this is there any way to reinforce the area, to make sure it wont happen? Is this only likely to happen on 1/2 ton and 3/4 tons or could it happen to 1 tons as well?
-Lincoln
Old 02-03-2008, 07:23 AM   #7
1974k5blazer
probly any i think they use the same frame rails!
Old 02-03-2008, 12:04 PM   #8
tvblazer78
Low & Fast!
tvblazer78's Avatar
Originally Posted by BLE 'BURBAN View Post
What Guy Does???
That's what I was thinking!!
tvblazer78 is offline   Reply With Quote
Old 02-03-2008, 12:13 PM   #9
abebummy26
abebummy26's Avatar
I dont think so I've seen my frame its a true 1 ton and the frame on a 1/2 ton plus the 1 ton frame is 8inches and the 1/2 ton frame is 6 inches 3/4 ton frame is the same as 1/2 ton though.
-Lincoln
Old 02-23-2008, 02:03 AM   #10
mtndewmaniac66
Do the Dew!
mtndewmaniac66's Avatar
Re: I dont like it when its loose and sloppy!
This gives me something else to look at! I have checked all steering components, including the rag joint, and all is tight. I guess I had better fix that before I put the 4" lift and the 3/4 ton axles underneath!
mtndewmaniac66 is offline   Reply With Quote
Old 02-23-2008, 10:29 PM   #11
mtndewmaniac66
Do the Dew!
So, last night, after reading this thread, I have crawled under my fender and had my wife work the steering wheel back and forth, and I cannot believe all the movement under there! I saw my steering box moving approx 1/16" back and forth, I witnessed the spring eye moving back and forth about the same amount, I saw the swaybar mount bracket, bolt AND rivet move about 1/16" as well, not to mention that the forward half of the drag link move in the socket! I can see how a total of 1/8" to 1/4" of movement can make the suburban wander! I was surprised to see the rag joint in good condition, and the rest of the steering linkage in good shape, nice and tight. I have parked it until I can get time to work on it.
Old 02-24-2008, 04:06 AM   #12
Zoomad75
K5Camper
Zoomad75's Avatar
You need this to fix the frame:
And you need this to prevent it from happening again:
Go here to get it:
http://www.offroaddesign.com/catalog/steeringkit.htm
Rob Z.
Old 03-05-2008, 04:03 AM   #13
mtndewmaniac66
Do the Dew!
Go here to get it:
http://www.offroaddesign.com/catalog/steeringkit.htm[/QUOTE]
I have mine ordered this morning. Fortunately, I did not have any cracks on the framerails, but I did nave a couple of rivets wallowed out.
Thank you, Zoomad75, for the link.
(I did not mean to hijack the thread, it just happened to be perfect timing)
