Old 02-13-2008, 06:18 AM   #1
OldCreek
OldCreek's Avatar
Dana 60 Crossover steering
Hey, did a search... no answers.
Can the driver's side steering arm be switched over to the passenger side to accomplish crossover steering? The kingpin cap from the passenger side then is switch over to the driver side. The drag ling adjuster sleeve could be split and a rod welded into the sleeve between each tie rod end.
The height of the steering arm is a concern... but I'd still be using the flat 44" leafs. This would place the steering arm just in front of center of the axle, not behind.
Your experience is appreciated!
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 02-13-2008, 06:45 AM   #2
hugger67
Re: Dana 60 Crossover steering
you can't reuse the arm the stock arm goes front to back and the crossover goes side to side arms should be pretty easy to find i'v got a few off ebay before also i wouldn't try and lengthen the tie rod make one out of dom or have one made you also need a 2wd steering box for crossover
hugger67 is offline   Reply With Quote
Old 02-13-2008, 04:56 PM   #3
earl87gta
earl87gta's Avatar
it wont work but you can get an arm on ebay for $50. I got my drag link from here last time http://www.shakerbuilt.com/Products.html.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
