CV joint
Is it a bad idea to remove the Cv joint assm. from the front drive shaft? They just seem like such a pain...
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
![]() Join Date: Jan 2007
Re: CV joint
I think it needs it because of the short length of the front driveshaft. Otherwise, there would be too much vibration and bind. I believe this is especially true if there is any kind of suspension lift.
I believe this is why Jeeps normally have a rear cv joint... their wheelbase is so short.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
Re: CV joint
As long as you never go over about 30 mph with the hubs locked in you can probably get away without it. It is there because of the way the u-joint angles are set-up on the front shaft. It eliminates the vibration you would otherwise get from mismatched angles.
Tim |
Re: CV joint
Hey thanks for the replies guys I think I'll just stick with the CV joint after all... It's gonna be my daily driver, not a hard core off-roadin' machine.
Re: CV joint
I removed my CV joint 15 years ago and I'm glad I did....no vibrations even at 80 mph. It's not lifted though.
Re: CV joint
Yeah... it's lifted 4 inches. I decided to just stick with the CV set-up so is there any tricks to putting it together? I took it all a part but it the seal and all that good stuff was gone so it just fell a part. I got the new U-joints and a new CV piece that bolts to the transfer case, but the guy at the auto parts store said there was some trick to putting it all together? Any comments or tips please let me know!
Thanks, J.D.
K5Camper
![]() Join Date: Mar 2004
Re: CV joint
Rebuilding CV's is usually left for a driveline shop. When mine was wasted I thought about doing it myself, but to actually replace the ball could require cutting the end off the shaft. From looking at mine and talking to a shop I know it's worth the money to have a pro rebuild the cv.
Rob Z. 1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP 1991 K5 8.1L/NV4500/241/D44/14b FWC Camper |
Re: CV joint
I just got mine back from HSV driveshaft yesterday afternoon. CV ball kit and sleeve and 2 new Spicer u-joints and labor was $117
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch 1995 T10 Blazer 4.3L 4x4 (Son's) 2004 GMC Envoy 4.2L 2WD 2005 GMC Sierra Crew Cab Z71 4x4 5.3L 240 Fun Finder Travel Trailer Harvest, AL 35749 |
Re: CV joint
He charged me 42.50 in labor in 2003 and 45 dollars labor in 2008. Not bad
Re: CV joint
This is what I got for replacement...circled in red. I'm not really sure what the big deal is with doing the replacement myself? Looks pretty straight forward...
Re: CV joint
It is all easy as long as the yoke (part #5) is not worn out. This yoke has a little boss that keeps the two u-joints aligned properly, and it can wear out. To replace the yoke you obviously have to cut and weld a new one on. I normally tear them apart, and if the yoke is OK you just put it back together with the new u-joints. If the yoke is bad take just the shaft to a shop and have them weld a new yoke on for you. That way all you will ever pay for is the part that you can't do at home.
Tim |
#12 | |
K5Camper
Re: CV joint
Tim's got it right there. On mine the ball/socket deal on #5 was worn out. It needed a new yoke. Got mine done for $77 through a shop I deal with. The big issue is when welding the yoke back on besides making sure it's true is making sure it's in correct phase with the joint on the other end of the shaft. If it's not in phase, the joints can't cancel each other out and it will vibrate regardless if it's been balanced or not. From what I've heard, even if you just end up replacing the part you circled you almost need 4 hands to get everything together correctly. Meaning it's not as easy as you might think it looks.
#13 |
Re: CV joint
![]() Thanks for all the help guys.
