Advanced Adapters 205 ??????????????????
has any one used AA's 05-0405 adapter for the 4l60e to 205 trans case? They told me it would need to be mofited a little?? I dont see at all u have to grind the @#$% out of it! Anyone had this problem???
Re: Advanced Adapters 205 ??????????????????
Picts? I'd call thier tech line before you grind it into an unusable peice?
done that the say it has to me modifed??? Buy there parts and throw away the stock ones and it should work!!
We ordered the 0405 and the 6900 to adapt the 205 to our new 4L65E. Have not gotten it together yet. Is there anything I should know about this part before I install it?
if u use the stock adapter that can with the stock 205 u will have to take about 5/8s off the stock adapter. that is what i had to do on myn i would post a pic but cant figure it out. AA told me if i order there 205 adapter for 279 dollors i wouldnt have to modify it. I couldnt see throwing out the stock part?? I wish they would make it work for the adapter they send u BUT It will work with some grinding
You need to adapt the adaptor?What application was it designed to actually work on?
they say to adapt a 700 or 4l60 to your 205 trans case it works but with some work
I have not had to modify one yet. The instructions say they may need notched, but all the ones I received were already notched. You should be able to use a stock TH350 adapter, but depending on what transmission you use, may require either changing output shafts or like some people have done, build an extension adapter.
Mike Redpath |
what i am using is a 4l60e trans to a 205 tcase the part that they send u dont need to be cut on but to put it to the tcase u need to modify your stock adpt and sleeve DONE IT or DOING IT
