02-17-2008, 11:57 AM | #1 |
How do you adjust a neutral safety switch
How do you adjust a neutral safety switch? Its a automatic tilt column?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
02-17-2008, 12:38 PM | #2 |
TILT COLUMN GURU
Re: How do you adjust a neutral safety switch
I always start truck put it in reverse shut off eng. then turn key on eng off I loosen screws to nuetral switch move switch till backup lights are on tighten screws. now it should start in park or nuetral.
02-17-2008, 02:10 PM | #3 |
thanks needed that help as well
02-17-2008, 02:20 PM | #4 |
what does the switch look like and wheres it located ?
im not sure if my truck has it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
02-18-2008, 10:49 AM | #5 |
I would like to know where it is to, can some one post a picture ?
02-18-2008, 12:53 PM | #6 |
TILT COLUMN GURU
It is the silver & black switch toward the end of column.
02-19-2008, 01:05 PM | #7 |
thanks
02-19-2008, 04:23 PM | #8 |
yup what he said. its easy. dont over think it!
11-29-2016, 09:32 AM | #9 |
I know that this is an old 'THREAD', but is this switch in the same location on a column 'without' tilt steering?
And, I replaced a bushing that was missing on my column [see picture of missing bushing before and after I made a bushing to go there...sorry the after picture is blurry] because of too much slop in column shifter. Was having to lift shifter up-and-down in Park because of having trouble finding the "sweet spot" for the NSS so truck would start. The slop is gone now, but sometimes I still have to push up a little on shifter for truck to start. If it is in same location, it's apparently under the inner fender well on 'my' truck because I don't see it and the steering column goes underneath the driver's side inner fender well. |
