Old 02-19-2008, 09:42 AM   #1
Nacogdoches55
Nacogdoches55's Avatar
Under Frame Leaf Springs
Has anyone relocated their leaf springs to underneath the frame on a 1955 - 59 Chevy?
I know you can buy a kit for the mono leaf but would a set of camaro or late model truck leafs work?
If you have this on you truck lets see some pictures.
Jeff
Nacogdoches55 is offline   Reply With Quote
Old 02-19-2008, 10:03 AM   #2
bfink
Re: Under Frame Leaf Springs
i've never seen them under the frame , but ive seen leaf springs moved to the inside of the frame rails . the guy had a narrowed rear end and some big micky t's out back with the bed tubbed out
bfink is offline   Reply With Quote
Old 02-19-2008, 10:20 AM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
There is someone that has posted pics of their 47-55 with the springs moved in under the frame. Hopefully they will enlighten us.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 02-19-2008, 11:06 AM   #4
55dude
55dude's Avatar
grab the hangers and all when you get the springs! no reason they won't work relocated under the frame. take the center to center measurement from the camaro and remount the springs on truck frame using those measurements.good luck.
55dude is offline   Reply With Quote
Old 02-19-2008, 07:41 PM   #5
orgalmeister
I think there is a kit sold that moves them under the frame...so I can't see why it wouldn't work. Just got to get the correct spring rate.
'56 truck (the never ending project)
'06 Z/71 loaded (daily driver)
'07 Mercedes-Benz C-Class (wife's driver)
Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod,
orgalmeister is offline   Reply With Quote
Old 02-23-2008, 12:17 AM   #6
mbgmike
What about these fellas
http://www.progressiveautomotive.com/rearleaf.htm
mbgmike is offline   Reply With Quote
Old 03-11-2008, 03:39 AM   #7
weldvair@embarqmail.
Well here is my solution to keep it low. I cut the rear of the frame off & welded a 2" x 2" square tubing to which I bokted the rear hanger. The best springs for these trk iare from a Mopar s.w.(fifth ave.)
Don Meyer
weldvair@embarqmail. is offline   Reply With Quote
