Old 02-22-2008, 06:20 AM   #1
Lrall
Lrall's Avatar
Exclamation Driver side door lock....anyone?
Im looking for anyone that has put a door lock on their 47-54 chevy pickup, i have a 48 with the external lock(not in the handle) and want a lock on the driver side. I thought there was a kit or something for this but couldnt find anything, i even searched. Pop in with any info positive or negative. Thanks fellas!!
Lrall is offline   Reply With Quote
Old 03-08-2008, 07:20 AM   #2
Lrall
Lrall's Avatar
Re: Driver side door lock....anyone?
ttt
Old 03-08-2008, 10:19 AM   #3
55dude
55dude's Avatar
why not just use a remote entry lock setup? my 98' grand cherokee had that setup and seems to work smooth. bet you could rob a setup off something in the boneyard. that way you could keep the key on passener side in case of dead battery or malfunction.
55dude is offline   Reply With Quote
Old 03-08-2008, 10:20 AM   #4
Lrall
Lrall's Avatar
i dont have power locks....sooo wouldnt that make it kinda hard?? i dunno, i just want a lock on that side and not to have to custom make something
Old 03-09-2008, 01:34 AM   #5
Cameo Carrier
Cameo Carrier's Avatar
I think you can use any 47-at least 59 guts out of the handle. I have key locks on both side and there keyed the same as the ignition and glove box.
Is that a camaro bed on that?
Cameo Carrier is offline   Reply With Quote
Old 03-09-2008, 01:34 AM   #6
Cameo Carrier
Oh, and you can find new kits anywhere or get them out of a deluxe cab.
Old 03-09-2008, 02:49 AM   #7
solidaxel
solidaxel's Avatar
47 to 52 does not have a push button handel.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-09-2008, 09:53 PM   #8
Daniel U
Daniel U's Avatar
It may be difficult if you want to keep you stock handles. I'm going PL to fix it as my '54 doors were ditched to have a 1 piece window.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-10-2008, 05:30 AM   #9
49S10
49S10's Avatar
I also wanted a drivers side key lock and installed the lock before I discovered the latch on the drivers side is different from the passenger side and is missing some important parts for the key lock to work. I had previously done this on a 56 F++d pickup and it worked fine. I don't know of any kits for this modification. I've purchased an extra passenger latch and plan to see if I can add the needed parts to the drivers latch. Just haven't had the time to deal with it lately. Let us know if you discover a kit.
49S10 is offline   Reply With Quote
