Old 02-26-2008, 10:51 PM   #1
malibu795
malibu795's Avatar
59 panel truck ? on alot of stuff
59 3/4 ton with w 9600GVW weight rating pacific body on it. straight frame naturally
manualy steering is shot... box manly.. planing on going to power steering... i saw borthers swap/upgrade and read what they did. any one got some pointers? or did brother cover majority of it?
brakes the previos owner re-did 3 out of 4 wheel cylinders and new master cylinder. it has what looks like a bastardized vacuum boost over hyd setup on the the pass side. it does lock up all 4 wheel on med- heavy pedal pressure... i want to convert to dual chamber MC for saftey reasons and convert to hydroboost so i can keep my manual tranny.....
it also has an eaton rear end... are there any code on the housing to dipic gears and dif setup?
i also heard the gm 14bolt brake hubs, carrier and axle shaft will fit inside? i would like to put soem dually drums on the back.. (13x3" brake shoes vs the 13x2" shoes.
leave springs... were can i get new eye bushings?
thanks adam
-A DAM WILD MAN-
59 apache pannel truck 38 I-6/sm420
79 malibu wagon 305/t56
02 2500hd duramax/allision 1/4 13.82 @100 mph efi live and built tranny
500hp 383 on the engine stand
U.S. Navy 2000-Current
Peace through Superior Firepower
Horsepower = Condom.....I would rather have it and not need it than to need it and not have it
malibu795 is offline   Reply With Quote
Old 02-27-2008, 09:42 PM   #2
malibu795
malibu795's Avatar
Re: 59 panel truck ? on alot of stuff
did i ask some off the wall question?
-A DAM WILD MAN-
Old 02-29-2008, 06:01 AM   #3
55dude
55dude's Avatar
no! check with the filling station or your local leaf spring builder.
55dude is offline   Reply With Quote
Old 02-29-2008, 08:32 PM   #4
dan42
dan42's Avatar
Let's see some pictures!!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-01-2008, 10:34 PM   #5
malibu795
malibu795's Avatar
pic im working it... laptop got stolen 3 weeks ago so things are slow
-A DAM WILD MAN-
Old 03-04-2008, 10:19 AM   #6
malibu795
malibu795's Avatar
here you go with a picture
vin is 3G 59 O 119361
trim STD
paint 718A
GVW 9600
the LMC catollog only goes to 3E for 3600 is 38 a 1 1/4 ton?
-A DAM WILD MAN-
Old 03-04-2008, 11:19 AM   #7
malibu795
malibu795's Avatar
forgot to mention it got 17.5" rims up front and 16" split rims out back
-A DAM WILD MAN-
Old 03-04-2008, 11:59 AM   #8
Daniel U
Daniel U's Avatar
Do you plan on clipping the front end with IFS?
Do the brakes 1st IMO. Better to be able stop than go and crash.
Dunno, should be a tag on the pumpkin though.
Already answered
thanks adam
N/P Daniel U
BTW, what are the rest of your plans for the panel before we give you anymore suggestions? It may help us answer you better. Again we love pics! hint-hint, nudge-nudge!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 03-05-2008, 04:54 AM   #9
malibu795
malibu795's Avatar
Originally Posted by Daniel U View Post
N/P Daniel U
put it back to work.. 454/sm465 is most likely going in the truck. got to do something about the 5.13 gears out back might update to a 10.5" 14bolt corpate axle with 4.10 gears. not that antyhing is wrong with the eaton that is in there.
when money promits ZF650 6 speed tranny
thing already on the to do list
electric wiper conversion
dual master cyl conversion with update hydroboost at a later date
power steering... gut feeling say i have a 1/2 manual steering box
get the pass door worrking and long with the driver side door rebuild the frames.
update tie rods ends
front wheel bearings? dont know if they are ball bearings/ roller bearing or tapered bearings but i can hear them when it was ona lift saturday.
75% of hte grease zerts wont take grease
the A pillar is ginda gone on the truck pass side the is the biggest rust spots.
-A DAM WILD MAN-
Old 03-05-2008, 07:00 AM   #10
malibu795
malibu795's Avatar
here are some pictures
-A DAM WILD MAN-
Old 03-05-2008, 07:02 AM   #11
malibu795
malibu795's Avatar
some more
suck only cna load 5 at a time
-A DAM WILD MAN-
Old 03-08-2008, 10:48 PM   #12
Daniel U
Daniel U's Avatar
Thnx for the pics! Looks like a sweet ride for a work truck!
