Old 03-14-2008, 03:53 AM   #1
felixkg
Exclamation "The Eaton Axle Blues!"
i know that my truck has a eaton axle, but i don't know which one it is. is it the HO72 or the HO52? what are the visible differeces on the two? can i ID it on my VIN? i want to buy that detroit locker for it, but i don't know how to ID the axle. can someone help me?
my truck: 1972 chevy k20 (c20 badging), 350/sm465, dana44 front axle, tuff as nails, ect...
felixkg is offline   Reply With Quote
Old 03-14-2008, 05:58 AM   #2
1969k10stepside
Re: "The Eaton Axle Blues!"
It should be a Ho52 if original.Post some pics of the truck if you get a chance.
1969k10stepside is offline   Reply With Quote
Old 03-14-2008, 06:08 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
except for brakes, it doesn't matter much, however...
If it is a 3/4 ton, and it is original, then it is an HO52... the HO72 was only installed in one ton trucks.
I moved this to the truck forum... you had it oin the suburban forum.
Old 03-14-2008, 06:52 AM   #4
pumpkin
pumpkin's Avatar
The detriot locker is the same for both the 52 and 72. The difference between them is that the 72 has a ring gear deflection bushing right oposite the pinion gear. There is a bolt and lock nut to adjust it, that you can see on the side of the carrier, if it is an ho72. If you can not find a locker for an eaton, one from a 14 bolt will bolt right in. You just have to use 14 bolt axles, as it has a different spline count.
pumpkin is offline   Reply With Quote
Old 03-14-2008, 07:40 AM   #5
Longhorn Man
the 52's had that too... I've had 3 HO52's...all of them had it, one of them was a coil rear, which has to be a 52 since they never made any one tons (ho72) with coils.
Old 03-14-2008, 04:36 PM   #6
Some HO52 rears had the deflection adjuster...correct.The lockers aren`t made anymore for these.You`ll have to find an axle with it or adapt the 14-bolt unit.It gets expensive.Lockers run around $500,used 14-bolt axles,cut & dressed,I`d do carrier/pinion bearings,and set-up cost if you don`t do rears...prolly around $800-1,000.
Try to find a used HO52 with "No-Spin"(locker) or look for a 14-bolt w/locker installed,for your cheapest route.
Old 03-14-2008, 10:44 PM   #7
Sinister
Between Trucks...
Sinister's Avatar
So that's it for limited slip options for the Eaton? That sucks...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-14-2008, 11:52 PM   #8
pumpkin
pumpkin's Avatar
I scored a new in the gm box, detroit locker for an eaton for $200,,,, its not for sale.
Old 03-15-2008, 04:58 AM   #9
I had to pass on a N.O.S. one for $500.You stole that for $200.
Old 03-16-2008, 09:44 AM   #10
BCOWANWHEELS
JERK THAT OLD OBSOLIETE REAR END, INSTALL A 14 BOLT AND BE DONE WITH IT. you,ll be glad you did and save tons of $$$$$$$$$$
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-16-2008, 05:51 PM   #11
Mike C
Mike C's Avatar
Not quite so easy with a coil spring truck, however. But there are some coil spring Dana 60's out there if you look. But either way, adding a locker to one that doesn't already have it will cost you.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-19-2009, 09:02 PM   #12
justcuz
justcuz's Avatar
Go to Pirate 4x4 and look at Eaton comments. There is nothing wrong with the Eaton HO 52 or 72. The brakes are the toughest thing to fix (drums are the hardest to find) but you can bolt on a 14 bolt disc brake kit to fix that.
The Eaton is just as strong, lighter and has more ground clearence than a 14 bolt. For anyone that has one and does not like it, I'll take every one you want to give away! If you are worried about axles and gears 14 bolt side gears and axles bolt right in. These rear ends are practically indestructible and most folks don't bother swapping the axles unless they are using a 14 bolt Detroit locker. To answer a final question, the No Spin (detroit locker) is the only traction aiding device for an Eaton. No limited slip clutch type traction aid was ever made for this rear axle to my knowlege.
justcuz is offline   Reply With Quote
Old 03-19-2009, 09:09 PM   #13
BCOWANWHEELS
also tire wear with a locker will be half of the tire wear with a open diff. gas milage will also drop. and on wet slick roads in a curve be ready for the rear to come around if it breaks loose. i,d do a modern 14 bolt and a limited slip personally for on road use. i have 2,ho52,s . srw & 1 ho72 drw if you need any parts.
bob
