Old 03-16-2008, 01:08 AM   #1
Kim57
Kim57's Avatar
Have A Question
On the front fenders what are you guys doing with the fill piece inside the grill?
I know removing it is easy but how are you reataching it?
Thanks for any info.
Kim
Kim57 is offline   Reply With Quote
Old 03-18-2008, 05:24 AM   #2
Kim57
Kim57's Avatar
Re: Have A Question
Seeing as I got no replys to the 1st question I'll ask another.
Has anybody removed it or are you just working around it?
Kim
Old 03-18-2008, 06:55 AM   #3
Brent5631
Brent5631's Avatar
Re: Have A Question
i dont know why you would want to remove it. i;m keeping mine like it is unless there is a good reason to change it.
1956 Chevy 3100 Big Window
Fuel Injected 6.0
Corvette Suspension
Four Link Rear
Brent5631 is offline   Reply With Quote
Old 03-18-2008, 07:26 AM   #4
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Have A Question
You need to keep it or you will end up with an opening inside the fender well.
CAL 58 GMC is offline   Reply With Quote
Old 03-18-2008, 09:19 AM   #5
Kim57
Kim57's Avatar
Re: Have A Question
I'm going to keep it I was just wondering if anybody took it out to make sure it gets totally cleaned of rust and then painted and reinstalled.
Mine had a rubber gasket stapled between them and the fender.
Kim
Old 03-19-2008, 08:09 PM   #6
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Have A Question
Hello Kim,
I removed mine for cleaning and I'm going to use some small stainless steel flat Allen wrench bolts to replace the rivets. You could also weld it and place.
I done that on my brothers old truck. The way I did it on my brothers truck was to take a screw (that fits tight in the hole) feed it through from the inside, cut off the excess and weld it on the outside and grind it flush. I like it
Kabwe is offline   Reply With Quote
Old 03-19-2008, 08:43 PM   #7
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Have A Question
Kim
Okay, I totally miss understood what you were trying to do.
Old 03-19-2008, 09:41 PM   #8
Kim57
Kim57's Avatar
Re: Have A Question
Originally Posted by Kabwe View Post
Hello Kim,
Thanks for the info Kabwe.
I was thinking the same thing but just wanted to know if anyone had done it.
Kim
Old 03-20-2008, 03:03 AM   #9
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Have A Question
Thats what happens when you finish your build and are riding around in a beautiful truck. You forget everybody else's pain.lol
Old 03-21-2008, 03:39 AM   #10
DavesRide
DavesRide's Avatar
Re: Have A Question
Chrome plate it and bolt it back in.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 03-21-2008, 08:18 AM   #11
Kim57
Kim57's Avatar
Re: Have A Question
I'm going for the monochrome look. The only chrome will be on the tail lights and head lights.
Kim
