03-19-2008, 09:53 AM | #1 |
rear suspension?
hey guys im new to the c10 scene i just got a 70 c10 couple weeks ago. i seen something under the bed, it has leaf springs. i havent done that much research. but i dont think 2wd c10s had leafs. i could be wrong but im lookin to you all for the answer. thanks in advance chad
03-19-2008, 10:20 AM | #2 | |
Gone to greener pastures
Re: rear suspension?
There are lots people around this board that have a ton more knowledge than I I just jumped in to say, "Welcome aboard!!!!" You'll find a lot of good help here.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
03-19-2008, 12:06 PM | #3 |
They did, they just werent as popular as the coil spring trucks. I thought the same thing for quite a while until joining the boards.
Welcome aboard!
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
03-19-2008, 03:17 PM | #4 |
1972 Chevrolet SWB
generally most GMC trucks were leaf and Chevys were coils and since many many many of these trucks are around and swapping parts and interchangeability is easy you dont know what you really have unless you decode it option wise. There are some coil equipped trucks that look like they have leafs from the back but those are overloads that have been installed and are half leafs to support the rear more on a coil spring truck.
Like most on this site will say,pictures really help trying to figure this stuff out. Most like me can spot things in a picture and can help out better that way........if the picture is clear and we can see whats needing info on of course. Welcome also,hope you hang out as much as most of us.
My New thread with pics (not my build thread yet.) http://67-72chevytrucks.com/vboard/s...46#post2573646 1972 Chevrolet 1/2 ton short wide bed,68 frt clip Project. 1980 Camaro Inherited when father passed,68K Miles 2003 Ford Mach1 FUN as Hell!! 2002 Dodge Ram 5-8 slam Rolling BillBoard (Gone not forgot) 2004 Dodge Ram HEMI 10" lifted on 37's and 2wd. |
03-19-2008, 03:51 PM | #5 |
rear leaf spring rears were an option for Chevy and standard for GMC.
1997 GMC Sierra Ext 1965 Mustang |
03-19-2008, 08:52 PM | #6 |
Texas Big Wig
Chevy came standard with coils or optional leafs
GMC came standard with leafs or optional coils |
03-19-2008, 10:02 PM | #7 |
I have leaf spring rear in a chevy long bed. Welcome aboard.
Mike 68 C10 LWB midnight blue metallic 307ci, 700R4, HEI front discs, leaf spring rear tilt steering wheel, stock ride height, rally wheels, 2007 Dodge Charger(Hemi) |
03-20-2008, 07:03 AM | #8 |
its all about the +6 inches
not all years of GMC were standard with leafs.
03-20-2008, 07:19 AM | #9 |
Hand Crafted C-10
Welcome to the family!
Both my DD and my parts truck are leaf sprung 1968 C-10's. Build sheet shows 04G50GA HD REAR SPRING.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
03-20-2008, 10:22 AM | #10 |
A BIG welcome to you.
03-20-2008, 10:31 AM | #11 |
thanks guys for all your help and you all seem really nice and friendly, unlike other forums ive been on. im glad you all took the time to help. i have more questions about this. ill post some pics. but how can i lower the rear more? my truck has to much of a rake. and i have pics of my rear shackles. they are rubbing on the bottom of my bed. is something wrong?
03-20-2008, 10:51 AM | #12 |
those are deffinitley drop shackles... for lowering the truck and they seem to be creating some friction between your bed and your springs... I'm not really familiar with the lowering process on a rear leaf truck.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project. 1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver. |
03-20-2008, 10:58 AM | #13 |
could i put lowering blocks in?
03-20-2008, 02:22 PM | #14 |
1972 Chevrolet SWB
lowering blocks on that set up would raise the truck.
03-20-2008, 04:01 PM | #15 |
this might help http://www.67-72chevytrucks.com/vboa...g+leaf+springs
you can put em back stock and flip the axle ( put spring on bottom of axle ) |
03-20-2008, 04:22 PM | #16 |
You can flip the axle.....maybe. We used to do it in my minitruck days. Oh I am so ashamed that I said that. If you are not familiar with the process it involves removing the rear axle from the leaf springs and putting the axle on top of the leaf springs instead of below. It gives you an instant drop of a couple inches and allows the use of lowering blocks to go lower if you want. You may need to C-notch the frame if you go that route. It is not as hard as it sounds. There is some pinion angle stuff you have to worry about but nothing that the folks on this board are not ready to help with. If you decide to go that route it will be cheaper than getting a full trailing arm setup for the rear end also.
03-20-2008, 05:01 PM | #17 |
those are NOT factory shackles (between leaf spring & bracket). they are too long. which is why they hit your bed. But the spring is supposed to be on top of the axle.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) Last edited by 1969K10; 03-20-2008 at 05:02 PM. |
03-20-2008, 05:12 PM | #18 |
You would end up with something that would look like this.
esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 03-20-2008 at 05:13 PM. |
03-20-2008, 07:21 PM | #19 |
Hot Rods For Life
ESL how big are those? They look like 3"
03-20-2008, 08:10 PM | #20 |
I had a 72 Chevy with rear leafs. The guys at the shop swore it was a GMC in Chevy trim until I showed them the option sticker.
-Scott- |
03-20-2008, 09:51 PM | #21 |
Blocks are 3' > 4,' .... memory is not what it used to be. Blocks are cut and shaped then welded into place. This is not my 70,' as it runs coils with 2' blocks. esll.
Tomorrow is for doing today's stuff. ************************************* This truck has just the right amount of energy for me! Author: Warren Lake .... (member) |
03-20-2008, 11:44 PM | #22 |
welcome, my 70 gmc has coils on all corners.
1950 dodge truck 1970 gmc custom 1972 toyota celica 1974 toyota corolla |
03-20-2008, 11:50 PM | #23 |
Hot Rods For Life
Just curious. I have 2" blocks and stock coils. I have not installed the blocks yet.
03-21-2008, 09:39 PM | #24 | |
Hey Zumo .... here's a picture uf 2' blocks with coils. esll.
