Small block in '53
I found a '62 283 4bbl to put in my '53 five window. I also have an SM465
4 speed to use behind it. Tips, advice and sources please. The torque tube is gone and a Camaro 10 bolt is in place. Will the center dump ram horns clear the steering box. |
Re: Small block in '53
I think you will have better luck with 70's Camaro exhaust manifolds, maybe a little clearence on the transmission x-member depending on your choice of muffler shops. A new Driveshaft will mate from your gear box to that rear end you have. If it were me I think I would look for a 3 speed unless you are pulling stumps!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
