Old 10-29-2002, 08:17 PM   #1
Twister
Disc Brake Conversion c20 to a c10
I am looking to convert my front drums on my 70 c-10 to discs from a 72 c-20. Will they swap right over? I have access to them for free so I'd like to make it work. What all will I need from the donor? I can get all I need Thanks in advance....
Twister is offline   Reply With Quote
Old 10-30-2002, 02:05 AM   #2
Big69C20 Toy
Livin' it up.
Big69C20 Toy's Avatar
Hmm i think the spindles for the 3/4 are bigger and you'll need tie rods and ball joints for the 3/4 ton parts. also the 3/4 stuff weighs more than the 1/2 stuff so i dunno how well all the old 1/2 ton parts will wear and or how the camber/caster and all that jazz will go. I suppose it'd take a li'l fudging but wouldnt be too bad i dont think.... someone's gota have better info.
-Greg;
Sold the 69 C20. It's off to a better home with more love!
Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires.
Big69C20 Toy is offline   Reply With Quote
Old 10-30-2002, 10:05 AM   #3
crazy longhorn
Fabricate till you "puke"
If you are doing a 3/4 ton convesion, you should swap the rear diff also to have the 8 lug wheels all around. the complete crossmember will swap in, or you will need spindles, rotors, balljoints, lower a arms(hole size is different 1/2-3/4 ton), tierod assys, & possibly the center link. for the brakes, you will need the prop valve & the master cyl. Good luck.....crazy AL
crazy longhorn is offline   Reply With Quote
Old 10-31-2002, 10:40 PM   #4
Fast68Chevy
Fast68Chevy's Avatar
youll need 3/4 ton arms and spindles along with the rotors and calipers of course, and the centerlink bar and tie rod ends too, and will need ot reroute all hoses and lines to up freont of the engine cradle like all 71-up trucks are setup.
i prefer 73-up hoses cuz are tons longer and pass through frme rail holes that exist already on our frames up in front of cradle.
good luck
Fast68Chevy is offline   Reply With Quote
Old 11-01-2002, 05:17 PM   #5
crazy longhorn
Dont worry about the top arms, just the bottom.......been there, & swapped that. My 3/4 ton has 1/2 to ball joints & spindles, but still has the 3/4 ton TOP arms.........crazy AL
Old 11-03-2002, 10:18 PM   #6
MikeB
MikeB's Avatar
I know for sure that the inner and outer tie rod ends AND the cross link are different on a C20. And since the tie rods have different threads, you'll need different tie rod adjuster sleeves. I'm not sure about the difference between 72 C10 and C20 ball joints, but your 69 ball joints definitely won't work with the 72 spindles. You CAN keep your brake lines routed behind the crossmeber if you use longer hoses and clamp them to the lower control arms. I think my hoses are from a mid 80s C10.
If I were you, I'd look into a kit from Early Classics or GMCPaul's that lets you use your stock ball joints and steering parts. The kits use custom spindles and stock 71/72 brake parts. They even offer a 6-lug rotor.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-03-2002, 11:52 PM   #7
crazy longhorn
I think most of the info is there between all the posts.....hope its not too confusing. Im not sure if Twister wants to keep 1/2 ton parts on the truck, or swap to 3/4 ton spec all around? At any rate, I agree with mike B, altho it would be a little more outlay in parts, an aftermarket bolt on kit would save a lot of confusion, & with the 6 lug discs you will only be messing with 1 end of the truck. If you want a 3/4 ton truck, the simplest no confusion way would be to bolt the complete 20 series crossmember under the truck......with all the steer linkage, spindles , ect.....then do the rear diff. To bolt the 3/4 ton spindles onto your crossmember , you will need lower A arms,all 4 balljoints, tierod assys(inners outers & sleeves). You will also need the center link, & if swapping from manual to power steering, you will need the pitman arm that is with the power box. you will also need the master cyl, prop valve, & lines for the disc brakes. I hope that will clear up any confusion i may have caused with the 'short answer". Good luck.....crazy AL
